It is currently Sat Jul 19, 2025 2:32 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Jan 29, 2013 8:48 pm
coopar wrote:
The fittings I have are 1/2" bsp push on fittings from enzed. They'd be the same as pirtek type wouldn't they?
As long as the hose is the 1/2" 500psi stuff, yeah probably the same.
Do the fittings have a plastic or metal hollow ring near the fitting nut? If so they are same.
I was more thinking of the crap black aftermarket `oil hose' and hoseclamps that aftermarket auto gearbox coolers came with. :oops:
PostPosted: Tue Jan 29, 2013 9:18 pm
I know you can get 300psi rated oil hose from autobahn for 1/2". If that isn't rated high enough then you have a problem :shock:
Bit of overkill for breather hoses though
