coopar wrote:
The fittings I have are 1/2" bsp push on fittings from enzed. They'd be the same as pirtek type wouldn't they?
As long as the hose is the 1/2" 500psi stuff, yeah probably the same.
Do the fittings have a plastic or metal hollow ring near the fitting nut? If so they are same.
I was more thinking of the crap black aftermarket `oil hose' and hoseclamps that aftermarket auto gearbox coolers came with.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
