It is currently Wed Jul 23, 2025 12:08 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Jul 11, 2005 8:11 pm
This should turn easily in the hole
so you have to turn the bush before it will come out?
(sorry for this thread going so long. :oops: )
http://photobucket.com/albums/v684/64morris/
PostPosted: Mon Jul 11, 2005 8:34 pm
It should move freely anyway. You don't have to turn it to gt it out, it should turn anyway. This is where the problem is i think.
Aaron
PostPosted: Mon Jul 11, 2005 8:48 pm
The bush is probably stuck in the sludge.. put the top flange back in and turn it a bit, or try putting 2 screwdrivers in there together, and grip them and the centre shaft with some multigrips. Once the bush turns it'll probably pull out. :wink:
PostPosted: Mon Jul 11, 2005 9:09 pm
ok that'll be tomorrows go at it. :wink:
PostPosted: Mon Jul 11, 2005 9:13 pm
(top flange?)
PostPosted: Mon Jul 11, 2005 9:44 pm
top flange = bit speedo cable screws onto. Has 2 lugs underneath that fits into the recesses of the bit you are trying to remove. Maybe enough to get to turn. Good luck.
Steve
PostPosted: Mon Jul 11, 2005 9:49 pm
8) thanks
