It is currently Fri Aug 08, 2025 6:46 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 204, 205, 206, 207, 208, 209, 210 ... 568  Next
PostPosted: Mon Jan 17, 2011 5:34 pm
Fitted new slave cylinder for the clutch. Installed a clubman heater matrix to help with some cooling since she doesn't have the heater in her anymore and went for a drive. The first time in months.
Stinking hot day and the temperature sat halfway up the gauge, big improvement on what I had before, at some stage I'll be adding an expansion tank too. I was really impressed at how well the old girl went.
PostPosted: Mon Jan 17, 2011 6:01 pm
Let the good wife give it a fang, i know it will be safe
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Mon Jan 17, 2011 6:13 pm
NAV-MAN
I got some new presents in the mail today.
I got my grp7 wheel arch flares and new floor pans.
Now the measuring, thinking, measuring, thinking, cutting, grinding, swearing, welding, grinding and more welding can begin.
Someone remind me why I decided to re do the floors??
PostPosted: Mon Jan 17, 2011 6:19 pm
You forgot burning holes in ones self :wink:
PostPosted: Mon Jan 17, 2011 6:22 pm
NAV-MAN
I've actually got welders gloves and sleeves plus an apron so I should be ok.
This time :roll:
PostPosted: Mon Jan 17, 2011 6:39 pm
fits wrote:
installed new doors seals and then proceeded to get all confused on how to remove the door window to fix the winding mechanism and install new felt seals. any ideas?
How'd you go with it??
Mearcats 'How To' here : http://www.ausmini.com/forums/viewtopic.php?t=60640&highlight=dismantle+doors might help!
The felt strips need 'clips' to fit them on. They were a PITA on mine to do :evil: !!
Cheers, Kim :-)
**purple '68 deluxe!**
***FINALLY wearing number plates----yeaaaaaah baby! ***
PostPosted: Mon Jan 17, 2011 7:07 pm
I put slightly bigger main jets in the Dellorto- the 1412 stroker sings better for its supper now. :P
PostPosted: Wed Jan 19, 2011 8:37 pm
Spent the last 2 days getting this work done...
was up all of last nite, just to get some spannering work done and worked all day until now, the list includes but not limited to is:
Replaced the steering rack with new one
stripped the engine bay completely including rad, head, manifold, master cylinders, wiring, wiper motor, etc etc, for grinding and prep work ready for new lick of paint and primer, (now painted :P)
Ripped up the inside carpet ready for new ones, which involved removing the seats..
Replaced the front two brake hoses..
installed hi lows in front
installed a electronic kit in this dissy to replace the worn points :)
Removed and cleaned the upper control arms throughly and inspected, then packed full of new grease, and new knuckle joints and boots..
A new double row timing chain fitted replacing the single stretched one,
A new high flow water pump fitted..
The head taken off, stripped completely and has been sitting in mollasses, (pulled it out today) and its done an awesome job, nice rust free water jacket now :),,
Cleaned and painted the stater motor, dissy, pulleys, engine steadys, and other small bits..
Radiator is just about back in now..
then head will be reassembled, and valves lapped and seated with better springs this time.. then painted of the head will begin, new master cylinders to be attached and the pipework, brakes to be bled, clutch to be bled, rust convert the floors, then installation of new carpet and seats to go back in,, then dash will come off for new 4 inch speakers to replace the crackling ones,,
hmm what else,,,oh obviously the head to go back on,,, and that will do me I think before the aussie day run..
Just a tad of work done
Saves me having to worry about it all on the side of the road on my 6,000km trip next month.. :)
:lol: :lol: :lol:
PostPosted: Wed Jan 19, 2011 8:44 pm
Had a steriod injection in my left wrist yesterday and I was supposed to be resting it for 48 hours. So I only did some retorquing of the head, reset the rockers and repacked the front wheel bearings and changed the front brake pads. :)
PostPosted: Wed Jan 19, 2011 9:31 pm
careful with the retorquing....you might over do it with them steriods :lol:
PostPosted: Wed Jan 19, 2011 10:17 pm
After not having working windscreen wipers for about 3 years i finally changed the motor and now they work!
PostPosted: Thu Jan 20, 2011 2:10 am
[quote="MG Rocket]careful with the retorquing....you might over do it with them steriods :lol:[/quote]
Ha ha funny :lol:
And here was me waiting for somebody to mention self pleasuring... 8)
PostPosted: Fri Jan 21, 2011 11:01 am
Last night picked up a pair of low back seats as a stop gap till I can get mine re-upholstered (thanks Neil)
Today started cleaning them up
PostPosted: Fri Jan 21, 2011 11:15 am
Crack tested 2x 1098 cranks for mattsmadmini.
Surprise surprise, neither was cracked.. so I kept the biggest (-10/-10)one. :lol:
PostPosted: Fri Jan 21, 2011 1:40 pm
finished applying mold release to my new arch molds, then waited, and waited!
Just layed down the gelcoat ( 8) black of course), now wait a little more and I can lay up the glass!!
:mrgreen: Cant wait!!
mick
mooo, I'm a pig!
