It is currently Fri Aug 08, 2025 9:42 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 207, 208, 209, 210, 211, 212, 213 ... 568  Next
PostPosted: Tue Jan 25, 2011 5:16 pm
Fixed the snapped off connector for the rear of the clubman speedo and attached it. I did have a screw on one but the screw on speedo didn't work so I made a good 3 gauge binnacle out of two not so good binnacles. :D
Since I have very manly man hands I ended up removing the drive shaft to get at the speedo drive on the gearbox, but as the hole on the subframe isn't big enough to pull through a whole pot joint I decided to chase some ball bearings around for a while when they fell out.. All back together now and I stink like CV grease. Yummo... :wink:
PostPosted: Tue Jan 25, 2011 6:40 pm
got defected :(
now for sale
1974 clubby with round nose conversion
1100 motor
extractors
twin 1 1/4" su's
lumpy cam (dunno what 1)
2 1/2" exaust
http://www.ausmini.com/forums/viewtopic ... sc&start=0
PostPosted: Tue Jan 25, 2011 6:41 pm
This space for rent
(SuX-855) wrote:
got defected :(
now for sale
Radical thought: You could.. you know.. fix it?
PostPosted: Tue Jan 25, 2011 6:45 pm
i dont have the resorces to fix it and the no how and money
1100 motor
extractors
twin 1 1/4" su's
2 1/2" exaust
PostPosted: Tue Jan 25, 2011 6:53 pm
Resources and Know how is probably available form our Adelaide AusMini clan, and cost wise i'm sure others can help find the bits you need at a good price.
Dont sell it, you'll regret it for years. I did.
Dicko
PostPosted: Tue Jan 25, 2011 6:57 pm
This space for rent
Sorry, I find that rather a lame excuse. In your ad, you mention you were defected for:
* Wheels too wide
* Steering wheel not ADR compliant
* Windscreen washers not working
That would have to be the simplest of things to fix...
* Swap your wide wheels for narrower.. most people consider wider = more valuable
* Find a cheap s/h Mini steering wheel, undo one nut to change it over
* Ask someone for help with your washers if you can't figure that out.
That lot can cost you approximatley nothing to fix.
But thinking about it, if that's too much for you to fix you're better off selling it...
PostPosted: Tue Jan 25, 2011 7:03 pm
it has to go through regancy so thats y
1100 motor
extractors
twin 1 1/4" su's
2 1/2" exaust
PostPosted: Tue Jan 25, 2011 7:04 pm
This space for rent
Our friends in NSW have to go through that every year...
What's that mean for us Easterners? Not having a go, just trying to help.
Dicko
PostPosted: Tue Jan 25, 2011 7:05 pm
gotta go over the pits and they will find heaps wrong with it
1100 motor
extractors
twin 1 1/4" su's
2 1/2" exaust
PostPosted: Tue Jan 25, 2011 7:07 pm
So does that mean you were driving a dangerous un-roadworthy car?
Ok. So they defected it for a few minor things, but because of that you now need to go over the Pits to get them cleared?
Bugger.
Dicko.
PostPosted: Tue Jan 25, 2011 7:09 pm
This space for rent
It surprises me (OK, maybe it doesn't) how many people see a compulsory road worthiness inspection as a bad thing...
If it would fail a Regency inspection in SA then frankly it shouldn't be on the road in the first place, defected or not.
PostPosted: Tue Jan 25, 2011 7:11 pm
it only has to go over the pits because of the steering wheel
1100 motor
extractors
twin 1 1/4" su's
2 1/2" exaust
PostPosted: Tue Jan 25, 2011 7:13 pm
Couldnt agree more. Cost me a few thousand to get mine roadworthy, and its better than causing a serious accident to yourself or others. Well worth it in the long run
