It is currently Tue Aug 19, 2025 6:27 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 279, 280, 281, 282, 283, 284, 285 ... 568  Next
PostPosted: Mon Oct 17, 2011 7:07 pm
Put my ausmini.com stickers on then took them off as the lettering was stuck on the wrong side i think. the sticky lettering was stuck to the contact. I tried to peel it off and it broke :/
PostPosted: Mon Oct 17, 2011 7:18 pm
SteveOB wrote:
Hi Steve,
Since the overhaul is the needle nice and steady?
Mine wobbles a little (+/- 2 mph) up to say 50 then starts to get worse. Also reads about 5mph fast.
I'm wondering if it's worth getting looked at.
it seems fine and steady yes - I took it back in there this arvo and he checked then and there why the miles weren't ticking over and showed me the tiny cog wheel was missing one tooth! - ten mins later he had replaced it and I reinstalled the speedo in his carpark and drove away a happy customer
$110 inc GST for the speedo overhaul
Good work!
I have been playing with speedos lately just to see what goes wrong and how you can get them right. They are fairly simple but you need a stock of spares, so $110 is just too easy! :D
The wavering needle can be caused by a cable or it can be dried up grease binding a shaft in the speedo. A service should fix it easily.
PostPosted: Tue Oct 18, 2011 8:15 am
Fitted my rev counter , done the washer hose, slowly getting there
PostPosted: Tue Oct 18, 2011 9:08 am
Fitted the timber dash, then the steering column and wheel. Looks like the steering rack may be out 1 tooth :( May have to dismantle and change so the blinkers will cancel correctly. More work :shock:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Oct 18, 2011 10:27 am
Hope it's not the one I did..
Standard pinion position (the later ones with the slot, not the groove) is with the slot at bottom when rack is centred.
There are only 5 teeth on the pinion, so 1 tooth is a long way, =72°
PostPosted: Tue Oct 18, 2011 11:05 am
Nah! Its the one I did with your bearings and pinion.
I think its good? The slot is at the bottom and I think I have aligned the blinker cutoff at 90deg or horizonal, which is incorrect as blinkers are a little higher than horizontal.
So yes I can't move the pinion as it would then be way out.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Oct 18, 2011 9:14 pm
Steering rack seems to be aligned OK so I fitted the front subframe tonight.
The rear subframe is tommorrow night.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Oct 18, 2011 9:51 pm
Nice work!! I have to replace a timing belt gasket! Bummer. wasnt leaking when it came out, but has now decided to leak!
PostPosted: Wed Oct 19, 2011 12:16 pm
Took it for a run, few issues...
The major one is my brakes work great!! But it takes a second for the brakes to release from when I take my foot off the brake!
Any ideas?? Going to drive it a bit more, just hoping its something a bit sticky after not being used for 10 months!
PostPosted: Wed Oct 19, 2011 7:20 pm
I've been engineered 8) :lol: 8) :o 8) :lol: 8)
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Wed Oct 19, 2011 8:06 pm
Milatsmadmini
fiddle sticks ya, still want to see this beast in the flesh... PS... Make a build thread please :)
PostPosted: Wed Oct 19, 2011 9:50 pm
Put in my new Klaxon horn under the right hand front wheel arch. Fits well but it does not sound that loud :/
PostPosted: Wed Oct 19, 2011 9:57 pm
Got a relay?
PostPosted: Wed Oct 19, 2011 9:59 pm
It's running direct through the alternator output fused to a switch which is rated at 16 amp.
The horn only draws 3 amps according to the packet.
PostPosted: Wed Oct 19, 2011 11:35 pm
well im out of ideas
