It is currently Tue Aug 19, 2025 10:34 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 290, 291, 292, 293, 294, 295, 296 ... 568  Next
PostPosted: Sat Nov 19, 2011 6:31 pm
MiniVLT wrote:
Yesterday I continued pulling my engine down for it's freshen up. Flywheel off, clutch housing removed & valves out of the head. Don't know who built this engine but the amount of clear silicone they used is beyond a joke!
Discovered that three manifold studs are siezed in the head, not even big vise grips will budge them, & the heads "unleaded conversion" hasn't been done, so need to find someone in Brissy who knows what they are doing with inserts as it's a pretty rare head, 12G938! The 35.5 inlets & 29.2 exh valves look good in it though! 8)
Shane
12G938 stamped in small letters near the thermo housing = it's just a common old Morris 1100S etc 1275 head.
Actually it is called a 12G940 because that number is cast in the middle, on top.
PostPosted: Sat Nov 19, 2011 6:49 pm
Interesting Doc! All my research keeps coming up with it's got a thicker deck and thicker castings around the ports. Mind you most of the info i found was UK based!
The 12G940 has also been removed from skimming the top surface of the head, only the 12G938 remains.
So do you have any std specs for the head?
Shane
PostPosted: Sat Nov 19, 2011 8:17 pm
Same specs as Mk2 Oz Cooper S 12G940 head (which is also stamped 12G1805) except for the following:
Missing the 2 extra stud holes (can be added no problem)
Has single springs not doubles
Missing inner spring locators (not needed with C-AEA526 aftermarket springs)
Inlet valves are 33mm not 35.6mm (these can be fitted after seats recut and ports blended in)
Also your head is much the same as the 12G1316 `smog' head (used on 1275LS and late 1275 Moke) except these are thicker casting around the exhaust ports and have air injection ports into the exhaust ports.
Chamber volume on all these 3 heads is 21.4cc.
PostPosted: Sun Nov 20, 2011 4:18 pm
Today I bled the brakes on my rover (wow what a difference that makes) and then just on a whim swapped the wires over on the voltage stabiliser on my minimatic... and now the fuel gauge works. Win! Kinda hate that after I've changed over all the connectors, bought and fitted a new tank sender... but oh well. Learn something new every day i guess. :D
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Sun Nov 20, 2011 5:14 pm
More fabricating a subframe assembly to mount metro seats in the estate. A day where some it is spent welding is always fun.
PostPosted: Sun Nov 20, 2011 5:33 pm
I got the engine started! It felt like a milestone moment, until I noticed the fuel leaking out of the "flexible jet tube". I pulled one of the carbs off and the tube that goes into the jet assembly was very worse for wear. it looks like the last time it was done someone hacked at it with a knife to make it fit....
Parts ordered, now to play the waiting for delivery game.
PostPosted: Sun Nov 20, 2011 5:54 pm
I just use a bit if fuel hose. A couple of dollars at the local parts store will buy a metre of hose which should last 1000 years if you just use it on SU jets.
If it is the O-ring in the bottom of the float bowl that is leaking you can make it from fuel hose, you cut a thin ring of hose and then remove the outer layer and use the inner layer as an O-ring.
PostPosted: Sun Nov 20, 2011 6:10 pm
Nice idea. When I went to investigate the flexible black tube from the float chamber body was just hanging in by a few mill's and it fell off. Lucky the exhaust wasn't hot......
PostPosted: Sun Nov 20, 2011 7:53 pm
Spent the past week cleaning and fitting the trim, glass and panels to the doors.
What a pain, especially the stainless trim around the tops of the doors
Only job left is the wiring and then drop the engine in
Sounds easy but the wiring is going to take a while to sort out, including adding in the mega jolt wiring and fitting the audio system
Oh! I forgot the fuel tanks and the body kit need to be fitted
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Nov 20, 2011 9:34 pm
Removed the engine. Found the clutch seal had split in 2 buggered how that happened :shock: and found a small hole in the timing cover seal. Maybe from the radiator hose rubbing over 40 years or the soda blasting fitted new timing chain. An d going to refit it next Saturday
PostPosted: Mon Nov 21, 2011 8:20 am
Washed and polished the newest member of the tribe - 76 Mini SS, 90% complete - only a few things to do to bring her back to her former glory.
Fingers crossed we get her registered this week :lol:
It's not the size of the dog in the fight, but the size of the fight in the dog!!
1976 Mini SS
1971 Mini Ute (Custom) - really hubby's but I will claim half :)
1976 Mini SS Shell
Oh and an 850 shell waiting for our dear son to start his resto!
PostPosted: Mon Nov 21, 2011 12:31 pm
Raced it at mallala over a two day meeting had a ball and dropped my personal best time by 1.2 seconds ( gotta love new hoosiers )
was coming first in class on in the last race when the windscreen became covered in oil and then he oil preassure dropped :(
back off a heap putted back to the pits
hope i havent hurt it too much :?
But on a good note still got second in class :D
Group Nc up to 2 litre
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Mon Nov 21, 2011 2:58 pm
Went and saw Mr Schmidt today and bought some new flares for the clubman spruce up
And pulled the clubman's engine bay to bits, ready to pull the motor and subby soon!
You're so square
Baby I don't care
PostPosted: Mon Nov 21, 2011 5:25 pm
had help to weld new floor in and ordered new wheels 15x7 standard mini stud pattern and readily available at your local tyre people just need to ask the right questions :lol: :D :lol:
PostPosted: Mon Nov 21, 2011 6:33 pm
What car are the wheels for???
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
Users browsing this forum: No registered users and 452 guests
