It is currently Thu Aug 21, 2025 1:01 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 304, 305, 306, 307, 308, 309, 310 ... 568  Next
PostPosted: Sun Jan 15, 2012 4:04 pm
Fitted the rubbers looks good. Bit weird as they have always been black but looks good.
PostPosted: Tue Jan 17, 2012 2:12 pm
Finished pulling the 1412 stroker out.
Found the RH CV boot is rooted- :cry: oh well, the 1360 motor will go in easier with 1 driveshaft out (I run H/S unis). :P
PostPosted: Tue Jan 17, 2012 8:53 pm
Removed the radiator cause it has no clearance between bottom bracket and the engine pulley and the body :(
Also discovered the new water pump has a loose bearing/ shaft :(
Although I am pleased I was able to remove it due to lack of space
Now the hard part will probably be to refit after I have improved the clearance
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jan 17, 2012 9:11 pm
I though i could stand up after wirewheeling my dash....
My head hurts
PostPosted: Tue Jan 17, 2012 9:35 pm
Forget to open the sunroof did ya? :P
PostPosted: Thu Jan 19, 2012 10:57 am
Received my wheel and Tyre package from Huddersfield :)
13x6 Sportpack copy wheels and Yokohama A539 tyres
1 week from order to arrival in Sydney.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Jan 19, 2012 2:01 pm
1360 is bolted back in but it's too hot out there to do more, and it's now beer o'clock anyway. :P
All 4 engine mount bolts slipped in nice, no crowbars or leverage needed with these (modified QH ones I had).
PostPosted: Thu Jan 19, 2012 2:20 pm
:shock: :shock:
Doesnt sound like a mini engine going in?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat Jan 21, 2012 11:02 am
Hooking everything back up- H/S joints, remote, steady bar- I must be getting old, it's taking too long... :lol:
It should run today.
Made up DrMini service tool #10- a C- shaped stand to lift the top arm a bit (hydro cars) to get the swivel hub back on. Should have made one years ago!
[edit] It's alive again! :P 8)
Last edited by drmini in aust on Sat Jan 21, 2012 4:30 pm, edited 1 time in total.
PostPosted: Sat Jan 21, 2012 11:34 am
Registered the last one. After this, no more.
PostPosted: Sat Jan 21, 2012 7:52 pm
Watched my mini depart my place on the back of a trailer..... :(
I know Tony (convertible mini) will look after it whilst in his care and it will come back with all electrical issues sorted out.
PostPosted: Sat Jan 21, 2012 8:03 pm
Pulled apart the heater and cleaned inside then while it is drying I fitted the right side fuel tank with the correct brackets which arrived this week from Minispares
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sun Jan 22, 2012 2:04 pm
i have just started building my red bull powered mini.
PostPosted: Sun Jan 22, 2012 2:11 pm
Well actually yesterday. I moved it. :)
I needed the space under the back pergola where the Mini has been living to do some spray painting 'cos it's out of the wind.
I'd forgotten how disproportionately big the turning circle is 'cos it took about a 15-point turn to make the 90-degree corner out to the driveway! I'd also forgotten how small it really looks when out in the open. :P
PostPosted: Sun Jan 22, 2012 4:38 pm
finished modding the ignition coil.
Users browsing this forum: stewartp and 76 guests
