It is currently Fri Aug 22, 2025 8:19 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 317, 318, 319, 320, 321, 322, 323 ... 568  Next
PostPosted: Sun Mar 25, 2012 5:43 pm
gave it a nice wash, took it for a quick squirt and then got it covered up :)
Basil - 1978 Leyland Mini, Brooklands Green, bit of a bitsa, and a park brick in the boot. :)
PostPosted: Sun Mar 25, 2012 6:07 pm
started putting the front subframe back together, progress at last
PostPosted: Sun Mar 25, 2012 6:40 pm
Well didnt do much to a specific mini just did alot of cleaning and fiddling with little bits and pieces... I didnt actually realise how much crap i had accumulated over the last couple of years. Time to get rid of and sell most of it... :?
Well here goes what i did today :D
I started to fiddle with alice and put some seatbelts in it. I was having trouble putting them in due to one of the bolts that holds the seat belt mounting brackets on was frozen stiff... Nothing an oxy torch and some swear words didnt fix though :lol:
finnaly got them in... :D
Has anyone tryed to remove inertia reels from a panel van before??? its bloody almost impossible. :evil:
Found this bad boy from a pile of moke stuff i had... Stripped it and painted it. Ready to be retrimed. Came up very nicely for a home compressor job :twisted:
Stole some bits of dads Cooper S for alice. He wont notice will he? :wink:
Found 123 grosso's new battery box... Guess where it was? Holding up the rear of the Nota fang :roll: 8)
Got half of my clubby back to bare metal and covered in Etch primer. Yes its also for sale So offer me something, Im very negotiable :)
Cleaned up alices new donk
Wanted to keep going but called it a day.
Also check out the for sale section soon im selling alot of stuff :wink:
Cheers, Steve
:D
PostPosted: Sun Mar 25, 2012 7:11 pm
Rubbed back the primer/filler on the clubman and discovered it needed some more :?
So that's what I did
Slowly getting the hang of using the HVLP spray gun, but it does have much less over spray
So now to rub back during the week and prepare for colour next weekend
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Mar 25, 2012 8:05 pm
The hydrolastic suspension was filled today. First time in 7 years the matic has had all 4 "boots" on the ground.
For those interested in someone to do on-site hydro fluid fills, Jay Styles is still providing this service in Melbourne (located in the SE). Ph: 0431 404 607
Getting there with the rebuild. Only been 8 years so far :D
WIll post some pictures soon in the Members Gallery.
1968 Mini-Matic ex998 Now 1098
PostPosted: Mon Mar 26, 2012 5:34 pm
Made a front lifting block as per the book. Easy with the right equipment at the Woodworkers Group I joined recently :wink:
PostPosted: Tue Mar 27, 2012 7:57 pm
Pulled the alternator out and fitted a spare one.
Now to see if it holds charge and doesnt kill the battery.
1977 Leyland Mini Van - Sold
PostPosted: Thu Mar 29, 2012 1:38 pm
Pulled the fresh 500 mile old clutch oil seal (GACO comp one) out of the 1360 and replaced it with a Payen one.
I'm damned if I can see why it was leaking- it looks fine. :?
It was fitted carefully using a spline protector sleeve too.
No, the oil wasn't coming through the primary gear, either.
We'll see if this seal is any better. :lol:
PostPosted: Thu Mar 29, 2012 8:11 pm
Othing :,(
1971 Mini Clubman 1100
1968 Morris Mini Deluxe 998
http://www.facebook.com/geelongminiclub
"Everybody should drive a Mini, everybody should own a Mini at some point, or you are incomplete as a human being." -James May, about the classic Mini.
PostPosted: Thu Mar 29, 2012 10:44 pm
Let us know how you go Dr! I have so far fitted 2 of the bloody things
PostPosted: Fri Mar 30, 2012 7:09 pm
Finally put the front disc hubs on the cooper s. They have only been sitting in the box for over a year :oops: The S is finally back on the ground :D
PostPosted: Fri Mar 30, 2012 7:17 pm
Hi Kev
post a pic of your seal puller, did you make one from the plans i posted a while back
PostPosted: Fri Mar 30, 2012 8:43 pm
kiwiinwgtn wrote:
Hi Kev
Nope, I made one from a Supercrap 3 leg puller I had-
I trimmed the legs at 1 end to fit the groove in the primary gear.
Also shortened the bolt and turned the 1st 50mm down to 13mm to fit down inside the crank.
That cable tie saves me having to have 3 hands... :lol:
[edit] Here's my alloy seal pilot that covers the splines, and the seal fitting tool that uses the flywheel bolt to push the seal in.
PostPosted: Sat Mar 31, 2012 6:49 pm
Kev, Clever use of a three prone prong puller
I managed to score the factory skyes puller set for this about 20 years ago at a junk auction for $10.00 makes the job so so easy
Its my best purchase ever right place right time
PostPosted: Sat Mar 31, 2012 7:06 pm
i managed to get around buying new flares, by fitting the 10x6's under the existing ones!
well maybe not..unfortunately i don't think it's actually a viable solution.. :lol: :lol:
.. looks like a fat bloke jumped on it to boot!
Users browsing this forum: Bing [Bot] and 93 guests
