It is currently Sat Aug 23, 2025 4:49 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 336, 337, 338, 339, 340, 341, 342 ... 568  Next
PostPosted: Sat Jun 16, 2012 7:29 pm
I took the cover of the S and cleaned the windows, checked the oil, water and tyres all ready for the run tomorrow. :)
Hope this rain stops as per the forecast.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jun 16, 2012 7:32 pm
Bled the brakes and adjusted the hilos..
the whole left of the car seemed to be 1cm higher compared to the right.
Fitted new mags and tires.. Found out the car had spacers on the front and no rubber bump stops :/
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Sun Jun 17, 2012 12:43 pm
Managed to get the engine off the trolley and into project Moke. Both subframes fitted and now on its new JBW wheels.
Dave K.
PostPosted: Sun Jun 17, 2012 5:36 pm
Looks great, theres something great about clean engine bay :)
Basil - 1978 Leyland Mini, Brooklands Green, bit of a bitsa, and a park brick in the boot. :)
PostPosted: Sun Jun 17, 2012 5:40 pm
Pulled the starter motor out and cleaned it up with a load of thinners, I can see whit was sticking now.
Just got to bolt the thing back on now :)
PostPosted: Sun Jun 17, 2012 5:58 pm
Went for a drive with the MCCNSW and ended up at Wilton.
Great day, great roads, thanks MCC
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sun Jun 17, 2012 6:42 pm
I hardfaced some worn remote change linkage balls with Toolcraft electrode, and reground them to fit. :wink:
Whatchacantbuywejustrebuild..
PostPosted: Sun Jun 17, 2012 8:06 pm
put the plunger in the clutch cover, added the lever, bolted the cover on, put the radiator on the other end. Ready to drop back in the car.
oh and bought a new garage with 3 bedroom house yesterday :lol: Got my weekends back to work on the car now, woohoo.
michael
PostPosted: Sun Jun 17, 2012 8:29 pm
Decided to put my steel wheels back on and wear out the brand new Falken tyres instead of my good yoko's
all on , torqued up , hub caps on and twenty bucks of fuel ,time to go for a nice easy drive . Northern rd , Bents basin , Wallacia , Silverdale , The Oaks
and the Coal road back to Camden .Stop at the traffic lights before the long bridge on the Camden bypass, (for those that don't know , called the long bridge because it is 1klm long from end to end ), One lane eachway and no breakdown lane. Off we go when the lights change ,merge into the single lane , hang on ,WHAT IS THAT SOUND?,steering starts to feel strange, pulling left, Don,t tell me its a wheel bearing :evil: can't stop here , have to get to the other end ,more pulling,more noise, more worry , get to the other end , pull over and have a look see. Not happy , but not as bad as I thought
Flat tyre , hope I haven't wrecked the tyre :roll:
mark
PostPosted: Sun Jun 17, 2012 8:38 pm
Fixed up the front apron, a little different, but I like it. Old one was bent like anything!
Finished off the bum and sanded & smoothed & primed some more panels, getting there, slowly. Found that a previous owner had a cooper S brake drum on one rear hub but not on the other, sigh. Finished off the boot weld with body deadener and will paint next opportunity. As far as I'm aware, we're pretty much rust free now? Yay!
1978 Leyland Clubman
PostPosted: Sun Jun 17, 2012 9:12 pm
Managed to arc out the terminals of the battery with my jack. Man what a way to kill a battery, kinda fortunate that it was due to be replaced anyway and that me and Hetty didn't go KABLOOIE :D . So now I have a new battery, new battery cover, new carpet in the boot and a new vinyl wrap for the jack and handle.... Whilst I was in there I installed a new rear reverse light under the rear bumper and wired it up. I finally put the horn back in and it even works. Next week I'm going to rewire the headlights to make them a tad brighter 8)
PostPosted: Mon Jun 18, 2012 7:35 pm
Got the sunroof glass for my mini sunshine Image
thanks Peter
PostPosted: Mon Jun 18, 2012 8:00 pm
Finally got my front end back together. New bushes, wheel bearings, bump stops, ball joints, adj. lower arms, adj. tie rods, tie rod ends and shock absorbers.
Made sure to grind in the ball joints with valve paste first, what an excellent idea!
PostPosted: Mon Jun 18, 2012 10:39 pm
tomtom wrote:
Is that horn up the right way? I just put mine on but up the other way. I would have thought having it that way would make it less horn, more gurgle which is why I turned it over... Or am I wrong?
PostPosted: Mon Jun 18, 2012 10:41 pm
Made my interior light work when you open the doors and then made it turn off when you close them. :)
Users browsing this forum: No registered users and 288 guests
