It is currently Sat Aug 23, 2025 3:05 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 345, 346, 347, 348, 349, 350, 351 ... 568  Next
PostPosted: Mon Jul 23, 2012 2:19 pm
Mokesta wrote:
Yes, with a multi meter. I disconnected the wires at the sender on the tank. When I measured the resistance across the sender terminals I got about 9 Ohms. The tank is brimming and the senders I have seem to range about 20 Ohms full and about 300 Ohms empty. Actually this sender is the lowest resistance at full of any I have come across. I was worried it may be drawing too much for the regulator.
Then I checked that the wire in the back of my gauge was the same one a connected to the sender as one was Green-Black and the other Black-Green :roll: . I did this with a long peice of wire and checking continuity on the meter. Beep meant the harness was made by the devil but still working.
Then I measured the voltage at the regulator. There are B and I markings. With the body of the regulator earthed and ignition on, one should read battery voltage and the other should read 10 Volts. Mine read zero.
I grabbed another off a spare speedo and swapped the wires over then tried the new one. My digital meter flickered as the regulator did its thing but it was near enough to 10V (DC setting on meter).
Put it all back together and the needle came up like it had just taken a blue pill.
I think I may have blown up the regulator when driving with the speedo hanging out of the binnacle as I tried to diagnose the lack of speedo worky. Maybe the fuel gauge terminals shorted to earth in the dash rail?
M
Thanks for the tips.
Looks like my sender is dead :/
I have placed an order for a new one.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Mon Jul 23, 2012 6:13 pm
Registered it!!!
Oh yeah baby. The 6 year resto is finally finished. Now, to fix all those niggly little things that continue to pop up.
Thanks to all who have offered help along the way.
Cheers, Matt
Don't be fooled, Gruhms is not my real name.
PostPosted: Mon Jul 23, 2012 6:17 pm
gruhms wrote:
Registered it!!!
Well done Gruhms!
I know the feeling :D (Although I waited 5 years less...)
PostPosted: Mon Jul 23, 2012 6:58 pm
You beauty !!!
Mike
PostPosted: Wed Jul 25, 2012 7:32 pm
Pulled the 1275 engine out of my Morris 850
PostPosted: Wed Jul 25, 2012 7:39 pm
Removed the exhaust and the Supercharger so I can replace the leaking manifold gasket.
This gasket is more critical on the inlet side due to the boost :shock: due to taking the charger on and off a few times the gasket now needs replacing
Need it to be all good for Sunday :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Jul 25, 2012 10:14 pm
Pulled apart my new 1275 I've just brought. Finished stripping and cutting the clubman up. Expect a big for sale thread soon with alot of clubman and early Morris stuff. PM me if there is anything specific you need as I most likely have it.
PostPosted: Thu Jul 26, 2012 3:30 pm
Fitted my shiny chrome and glass fuel filter.... looks heaps better than the big plastic thing, and looked at my new Bluecol radiator tag
PostPosted: Thu Jul 26, 2012 7:56 pm
Bolted the 1100S into my Morris 850.
PostPosted: Thu Jul 26, 2012 8:12 pm
This space for rent
Drove it, to the distinct smell of raw fuel. I've noticed occasionally one (or both) float bowl valves tend to stick open, and raw fuel spills out the overflow and down the heat shield over the extractors :shock:
Couldn't really stop in the middle of the West Gate Freeway, so did the next best thing and hit the fuel pump cutoff switch, which stopped the stink.
The good thing about having twin carbs is that the car will run for 500m or so on the fuel in the bowls, before I needed to turn the pump back on briefly.
Made it home without becoming a fireball, which I consider a success :lol:
PostPosted: Fri Jul 27, 2012 7:34 pm
Got the 1100 S running now I just need to connect everything properly and test drive it.
PostPosted: Sat Jul 28, 2012 11:26 am
Managed to snap the small length of wire on the indicator stalk for the lefthand side indicators. It was sitting on the contact, but not enough to make things flash, went to bend it slightly and it came straight off. These porrly made pieces of crap and really annoying me.
I ended up putting my old one back on, no highbeams, but at least I have indicators!
WTB coming soon.....
PostPosted: Sat Jul 28, 2012 6:47 pm
Tested a pair of Pulsar dizzys for an ausmini member. Unfortunately, both had dead electronic modules, so no sparky. :cry:
This is pretty uncommon, I've only seen 1 of these fail before.
Not sure how caused.... I've left ignition on with these lots of times with engine stopped and never killed one. But this does kill other modules for Lucas dizzys (eg. cheapo UK sourced ones and also Pertronix 1).
Last edited by drmini in aust on Sat Jul 28, 2012 9:52 pm, edited 1 time in total.
PostPosted: Sat Jul 28, 2012 7:33 pm
Washed the car ready for tomorrow,
Fitted the freshly painted sump guard,
Fixed my horn issue.
PostPosted: Sat Jul 28, 2012 7:43 pm
Changed the oil and filter, greased front and back
Spilt the oil :( when refilling
Replaced the manifold gasket
Swapped the wheels ready for tomorrow
Went for a test drive and noticed with the 13x6 wheels the steering is lighter
All good and ready for tomorrow
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: winabbey and 229 guests
