It is currently Thu Aug 14, 2025 5:19 pm
 Post subject: whats your idle speed?
PostPosted: Sat Sep 03, 2005 7:53 pm
Whats everyone set their idle to?
I've got twin HS2s with around a 1100cc engine... If I set the idle any lower then about 1100~1200rpm, after accelerating then letting it idle the engine will slow down then stall. So currently it's set to idle at around 1200rpm.. The book says it should be around 800-1000 anyone know whats wrong?
PostPosted: Sat Sep 03, 2005 7:57 pm
NAV-MAN
NAV has a very similar issue atm. Everything was all fine till i put on the lcb extractors and 1"3/4 exhaust. Now my mixtures are all over the shop.
And yes it is a ritcher needle i just need to get him onto a dyno to get it sorted 100%
Would auto tranny fluid be thicker than sewing machine oil?
PostPosted: Sat Sep 03, 2005 8:15 pm
1115cc, RE13 cam, twin HS2's = 1100 - 1200rpm idle. Anything below that and it's a dog!
PostPosted: Sat Sep 03, 2005 8:30 pm
Yeap...similar specs to anton..~1200rpm..same with most i've seen, nothing to worry about.
PostPosted: Sat Sep 03, 2005 10:49 pm
900rpm, with 731 cam, smooth as
it has to be less than 1000rpm or it drives me nuts.
your problem might include a sticky carby piston/s
or maybe fuel surge?
PostPosted: Sat Sep 03, 2005 10:51 pm
could be too rich aswell, which would make the idle lumpy
PostPosted: Sat Sep 03, 2005 11:42 pm
1 1/2" SU
Extractors
Idle speed is now sitting comfortably at 1000 to 1100.
sometimes drops to 600 - 800...that sounds tough :D
No more Minis!......For now.
PostPosted: Sun Sep 04, 2005 6:44 am
Online
Both Barney and Ha-Ha idle at 1100-1200. Barney (twin HS4s) sounds cammier than Ha-Ha (45 Dellorto) although Ha-Ha has a bigger cam.... :shock:
PostPosted: Sun Sep 04, 2005 6:50 am
yep Morris sits around the 1000-1100 also
1152 Hif44 re13 cams perry extractors 202 head
PostPosted: Sun Sep 04, 2005 3:30 pm
Lillee idles at 1100rpm, 1000 and is still ok but 1100 is just nice (1152cc 266 cam, dellorto45)
Lillee - 1969 Morris Mini K
PostPosted: Sun Sep 04, 2005 3:56 pm
teh admin God
teh admin God
whats an idle :? :(
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Sun Sep 04, 2005 4:00 pm
RPM of ure engine when its sitting there when running.
no foot on accelerator etc etc
Just sitting there with engine idling
PostPosted: Sun Sep 04, 2005 4:17 pm
Don't you want a high idle to help (splash) lubricate the cam, or am I dreaming...?
PostPosted: Sun Sep 04, 2005 5:03 pm
Online
That's one reason I idle mine at 1000+. :wink:
PostPosted: Sun Sep 04, 2005 9:06 pm
1200-1300rpm here. Just off topic for one second but still kinda on the idle thing.
Arrived at Russell(rustle!!)Offices Thursday morning and Henry decided to chuck a hissy fit and wouldnt idle. Backed into my usual park and popped the bonnet. So much for the "learned" advice saying dellorto's wouldnt ice up - no matter how cold it gets - the dellorto was nearly all white!! Covered in a fine powdering of ice so the innards must have been absolutely caked in it. Wouldnt idle at all and when the ice melted it would only idle at (just)5-600rpm.
After a day in the sunny Canberra sun it was good as gold...sorry for the hijack...
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
Users browsing this forum: 1071 S and 176 guests
