It is currently Thu Aug 14, 2025 7:27 pm
 Post subject: crabbin mini
PostPosted: Sun Sep 11, 2005 12:58 pm
how do I align the rear subframe?
my mini is crabbing, is there an easy fix?
PostPosted: Sun Sep 11, 2005 2:07 pm
It's probably had a hit in the rear, or clobbered a gutter sometime.
Maybe the subframe is bent, or a trailing arm.
Once you are sure nothing's bent you can put shims in front of (or remove from) the outer radius arm mounts to align it, but watch the rear toe-in is equal both sides.
Users browsing this forum: No registered users and 204 guests
