It is currently Sun Aug 17, 2025 4:56 am
PostPosted: Wed Sep 14, 2005 10:40 pm
Pulled the plugs out of my employer's LS today to see why `it won't start'. They were all black as.. from people over-using the choke to get it in & out of the factory.
So, I used DrMini emergency tip #1-
Light oxy (or blowtorch), heat the biz end of plug gently until centre electrode insulator is nearly red. All the crud on it just vaporizes away.. :P
Started 1st kick too....... 8)
PostPosted: Thu Sep 15, 2005 6:37 am
Wire wheel on the drill also works loverly also :wink:
PostPosted: Thu Sep 15, 2005 6:39 am
yeah!! both ways work well. when i was at school I gave my mate a set of my plugs to clean on a wire wheel, and he melted all the tips off them. :shock:
PostPosted: Thu Sep 15, 2005 6:42 am
Folklore has it that a wire wheel should never be used to clean plugs. It leaves steel wire particles embedded in the insulator which can cause the plug to fail....
Wouldn't you stop at the first one after stuffing it up?
Anyway very fine steel wool works aswell.
PostPosted: Thu Sep 15, 2005 6:43 am
Nar they get imbedded in my head
PostPosted: Thu Sep 15, 2005 6:47 am
dip it in petrol to clean all the steel shavings off after
PostPosted: Thu Sep 15, 2005 7:13 am
u would think he would, he was in first year auto but :wink:
PostPosted: Thu Sep 15, 2005 8:57 am
I tip my hat to you yet again Doc.
Hmmm.......all these tricks that you know - you should write a book and sell on AUSMINI and make some $$$$$'s it would be full of the stuff that just isn't in the workshop manuals etc.
I'll have one..........please.........how much?
Rod Image
PostPosted: Thu Sep 15, 2005 9:17 am
Hell, just a corrected workshop manual would be great :lol:
PostPosted: Thu Sep 15, 2005 9:56 am
Thanks for the tip will have to remember this :)...
Opinions expressed by me are of my opinion only and are copyrighted to Kinkabell Corporation? 2006.
PostPosted: Thu Sep 15, 2005 3:56 pm
You're supposed to use it on the plugs :roll: :lol:
PostPosted: Thu Sep 15, 2005 9:22 pm
i normally just use a file, then a little file for the tip of the electrode and the curvey arm thingy that goes over the electrode, making the gap
78 Leyland Mini - Prince
PostPosted: Thu Sep 15, 2005 9:35 pm
These 4 plugs' insulators were black as, covered in so much crap, oil and fuel that not one would fire.. :shock:
After `the treatment' they looked new!
Still gotta pull the head off it next week- compression is pretty low on one lung... the doctor has diagnosed a burnt valve... :lol:
 Post subject: File Card
PostPosted: Thu Sep 15, 2005 10:30 pm
I cut up File Cards on a band saw into long (handled) plug cleaners. So what you end up with is a mini wire brush about 1.5cm wide and say 15cm long.
To get down around the ceramic insulator I use a small Jewelers Screwdriver.
Users browsing this forum: No registered users and 269 guests
