It is currently Wed Jul 23, 2025 11:29 am
 Post subject: Gearbox Mount trouble
PostPosted: Wed Sep 28, 2005 6:20 pm
I gots a problem... one of my gearbox mounts is fruited..... and its caused my exhaust to move and now the whole car makes funny noises...
to fix the exhaust i need to fix the mount... problem is i dont know where they are and are they fixable wit the engine in the car?
can u guys shed some light? would be great
also if anyone has a pic of the under of the car and can hi-light the mounts this would be much appreciated...
thankz in advanced dudes and dudettes
PostPosted: Wed Sep 28, 2005 6:22 pm
both can be done in the car. the left is easier than the right. which is it? No point in explaining both if you only have to do one.
Aaron
PostPosted: Wed Sep 28, 2005 10:23 pm
i would tell u but i dun know where to look? what am i lookin for?
PostPosted: Wed Sep 28, 2005 10:42 pm
OOOOkay. Look under the car, from where the engine goes back to where the gear lever pokes up throgh the floor to your hand. Is there a big aluminium tunnel under there or just two steel rods?
If it is the FIRST: There is a mount at the back of this tunnel. Back to the engine bay, and there should be one stabiliser bar going from the motor, on the drivers' side going from the motor to the firewall. The bushes in these often rot away, and then the engine may wobble at the top, front-to-back.
If it is the SECOND: There are no mounts back here, but there are two stabiliser bars, one the same as the one already described, and one that looks the same, but it runs from the top of the thermostat housing to the back of the engine bay, on the passenger side, onto a rather agricultural looking steel angle-mount. This should have your heater hoses running through it, into the heater in the cabin. This is the replacement mount for the lack of the one at the back of that aluminium tunnel on earlier cars.
Users browsing this forum: kirby and 93 guests
