It is currently Tue Jul 01, 2025 7:33 pm
 Post subject: Thermo Fan
PostPosted: Fri Oct 14, 2005 4:43 pm
was just thinking - there's plenty of room between the radiator and the bars inside the wheel arch - fitting a thermo fan from a modern car cant hurt even if it doesnt help - which fans (from what cars) generaly fit you reckon. what fans have people here used? How did you attach them?
Any other tips? (besides get a better rad. or an auxilary core)
PostPosted: Fri Oct 14, 2005 4:46 pm
Mike,
I've got a spare leccy fan if you wanna play with it... :wink:
PostPosted: Fri Oct 14, 2005 5:53 pm
Here are a couple of pics of my new Moke radiator.
Note how the Jap thermo fan blades are designed for low noise (unlike a VK Commodore)
and the curved shroud to promote laminar flow.
This shroud is steel, but many are just plastic. Says "Lenzer" on so I guess its from a Lancer.
The radiator is an alloy Nissan unit I think. I just mixed and matched to get what I wanted.
PostPosted: Sun Oct 16, 2005 12:04 am
Just a thought, does anyone have a pic or dimensions of Pulsar thermo fan & shroud?
If we are going to pull the dizzy & alternator off a donor car, maybe the thermo fan will be a fit too... :? Has anyone done this?
PostPosted: Sun Oct 16, 2005 12:07 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
mike do you mean linier or am i just pre empting ??
makka
PostPosted: Sun Oct 16, 2005 12:23 am
mylse laminar means smooth/streamed
opposite to turbulent.
Inconspicuously Conspicuous
PostPosted: Sun Oct 16, 2005 12:38 am
Yes Matic has it.
Flow across a flat surface (or in a pipe for that matter) is in layers travelling at different speeds, with those next to the surface (or the inside surface of the pipe) travelling slowest.
of course in the case of that shroud, it would really be transitional.
laminar > transitional > turbulent
Good smooth flow makes a huge difference to the effectiveness of a cooling system or an engine intake :wink:
PostPosted: Sun Oct 16, 2005 3:47 am
Transitional or laminar - this thing will never fit behind a mini radiator - or would it now? (Can it be mounted externaly?)
PostPosted: Sun Oct 16, 2005 5:41 am
The alloy radiator & Lancer thermo fan (above pic) will be front mounted in the Moke
but from memory the Nissan Pulsar fan is much more compact. I suppose I will just have to go measure one :?
PostPosted: Sun Oct 16, 2005 7:02 am
Mike, you can just mount it to the inner guard where the grille bars are, make a tin shroud if you want. Many people don't bother.
You would also need to seal around the rad with a strip of rubber, like early Minis had originally. :wink:
