It is currently Fri Aug 15, 2025 5:15 pm
 Post subject: A few Questions
PostPosted: Mon Oct 17, 2005 1:41 pm
Hi All,
I have a few questions,
1. Does anyone know the Ohm range of the mini's fuel sender, I'm looking at purchasing some gauges and need to know this to get the correct one..
2. I have a set of dry subframes waiting to be fitted, what I need to know is the size/thread of the four top mounting bolts on the front subframe as it didn't come with any...
Thanks
Mat
PostPosted: Mon Oct 17, 2005 1:52 pm
1. Off the top of my head, pretty low, around 50 or 100 or 200 Ohms if I remember correctly. Why don't you just measure it?
2. Dunno which bolts you mean. The ones that go into the towers? Or the ones that go into the front beaver pannel?
PostPosted: Mon Oct 17, 2005 2:04 pm
Sorry I should have been more specific... The ones that go into the towers.
Mat
PostPosted: Mon Oct 17, 2005 7:36 pm
Tower usually has studs. Post something in the wanted section. Someone might post you some for nix.
I couldn't find a better picture of mine than this:
PostPosted: Mon Oct 17, 2005 7:43 pm
Dry cars here had studs, wet ones all had bolts. Why? NFI.... :lol:
