It is currently Fri Aug 15, 2025 11:16 am
 Post subject: Rear carpet installation
PostPosted: Mon Oct 17, 2005 7:42 pm
Hi,
What is the best way to cut the carpet at the rear to allow it to slide under the seat support (how should it be done!) You could cut a chunk out, slit it once and then again at a right angle?
PostPosted: Mon Oct 17, 2005 7:47 pm
I'd slot it in a 'T' shape.....so that it hugs that centre bit when it's all in......
Jeremy
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
PostPosted: Mon Oct 17, 2005 7:48 pm
i cut a hole where the post goes, nice tight fit, then make an incision below the main aorta... i mean make an incision form your fresh new hole to the back of the carpet. you may want to edge it properly or something, i didnt and its not falling apart, but i can't imagine it being a bad idea.
also you will need to cut a hole for your rear seat mounts, im not sure whether the new carpets cme whit this or not though.
also seat belt clips and handbrake
78 Leyland Mini - Prince
PostPosted: Mon Oct 17, 2005 8:07 pm
rear seat mounts?
what rear seat mounts?!!
Thanks for replies btw, T thing soundeth good.
PostPosted: Mon Oct 17, 2005 8:29 pm
oh sorry i meant the front seat mounts (but they are at the bcak of the front seats... :oops:
Users browsing this forum: No registered users and 191 guests
