It is currently Thu Jul 31, 2025 5:56 am
 Post subject: Can I ???
PostPosted: Wed Oct 19, 2005 3:23 pm
Hey everyone,
Can i remove the uni-ball joints (aka cv) and the cv boot without removing the wheels?
Lucas
PostPosted: Wed Oct 19, 2005 3:27 pm
YES
PostPosted: Wed Oct 19, 2005 3:29 pm
Woohoo!
So I just remove the u bolts and itll all drop out?
Lucas
PostPosted: Wed Oct 19, 2005 3:41 pm
NO
PostPosted: Wed Oct 19, 2005 3:44 pm
Okay so how do i do it?
PostPosted: Wed Oct 19, 2005 3:52 pm
There is a big nut at the wheel end of the drive shaft. You got to remove that before you can remove the CV and shaft from the vehicle.
PostPosted: Wed Oct 19, 2005 3:55 pm
You mean the nut that holds on the hub for the drums?
Can i just undo the u bolts to remove the boot and the uni joint? I dont want to actually remove the shaft!
PostPosted: Wed Oct 19, 2005 4:07 pm
Are you trying to replace the CV boot ? outer or inner? or do you have the uni joints ?
If you are replacing the boots inner or outer you will have to disconnect the drive shaft at the inner joint if it's the outer CV boot you want to do you will have to take the drive shaft and CV joint out. I had to split one of the ball joints to do this.
Roads need more corners
PostPosted: Wed Oct 19, 2005 4:10 pm
Im trying to remove the boot closet to the uniball joint. I also want to replace one of uni joints (rubber) with a newer (steel) one
PostPosted: Wed Oct 19, 2005 4:18 pm
Oh, OK i guess you just undo the U bolts slide it out of that telescopic type joint bit replace the boot / seal and put it back in.
PostPosted: Wed Oct 19, 2005 4:20 pm
Sweet! Im going to try it now and ill get back to u
PostPosted: Wed Oct 19, 2005 4:53 pm
I cant get it out :( the two u bolts facing the gearbox get caught when i try to push them out :(
PostPosted: Wed Oct 19, 2005 4:55 pm
Is that the nut that holds on the hub?
PostPosted: Wed Oct 19, 2005 5:05 pm
To remove 2 you have to first take off 12
PostPosted: Wed Oct 19, 2005 5:15 pm
AFAIK he doesn't want to get (2) the CV joint out but further towards the centre of the car there is a small rubber boot that covers a splined sliding joint type thing which is used with the steel uni joints and the rubber uni joints but not with the pot joints.
he wants to get this off and replace it and also get rid of the rubber uni joints right :?: :oops: :lol:
Users browsing this forum: No registered users and 72 guests
