It is currently Tue Aug 19, 2025 12:02 am
 Post subject: Not starting!
PostPosted: Fri Nov 11, 2005 9:12 am
My car wont start easily! :(
In the mornings the car hates me! It tries to turn over but it sounds like its not sparking the fuel. (Or something like that) What should I be looking at to figure out where this problem exists????
I looked at the rotor, dizy cap, leads, (new spark plugs), coil is getting electricity
anything that i've missed? Or should I take a second look at it all?
One other problem that i've noticed is that when driving it seems to miss a fair bit when doing 60ks (roughly).
Any ideas would be most helpful.
Specs on car is:
1100S
1 1/4 SU Carb
nothing special added or done to it
1975 Leyland Clubman 'S'
1976 Leyland Clubman 'S' *work in progress*
I smile everytime!
PostPosted: Fri Nov 11, 2005 9:18 am
running rich maybe? Have you adjusted the mixture recently?
PostPosted: Fri Nov 11, 2005 9:20 am
air leak somewhere - check the nuts on the intake/exhaust are all wanged up.
I found if mine didnt crank over, pulled the plugs and found I was running way too rich - lean it down a bit and see how you go(remembering where the nut was before you moved it though...)
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Fri Nov 11, 2005 9:27 am
How old are the plug leads, did you check the points, it could be anything really start with the basics like points gap and are they ok, not pitted to much, get a cheap multi meter that will check resistance and volts and check your plug leads, check the voltage to the coil when cranking the car over. Check inside dissy cap, is the little carbon button ok in the middle, has the rotor button got a dirty end as I said it could be anything but a cheap multi meter will help you check
Jon
PostPosted: Fri Nov 11, 2005 10:04 am
Rich? It might be, not sure. I was getting it looked at by Melba Motors and he fiddled with the mixture. It was running really bad when I took it to him.
Not sure about the mixture now as when i try to start it I need to pump the acc pedal. :shock:
I smile everytime!
PostPosted: Fri Nov 11, 2005 10:10 am
To advanced maybe retarded, closed points or condensor?
Check points are opening and closing
steve
PostPosted: Fri Nov 11, 2005 10:14 am
Pumping the pedal will do nothing on an SU, When you say you check the leads, points etc. what did you look for?
You can get a multimeter and test the leads for resistence.
It could be a combinations of everything, weak spark, timing, points, leads..
PostPosted: Fri Nov 11, 2005 12:25 pm
Wow, help really does flow in this place. :D
I checked the dizy cap (its clean), the rotor button is clean
when you refer to points what are they? (not used to the lingo)
how would I go about doing the below?
steve
I smile everytime!
PostPosted: Fri Nov 11, 2005 12:30 pm
points are what are under your distributor cap...see blow..
if you roll the car back and forward in 4th gear you should see them open and close, they control when a spark is sent to the plugs.
PostPosted: Fri Nov 11, 2005 1:47 pm
Careful when you change the points that the wire isn't shorting out to the base plate inside the dizzy cap..... :oops:
Daily Driver - Yellow Devil 76 Clubman
Restoration Project - Primer grey 66 Morris Mini Deluxe
PostPosted: Fri Nov 11, 2005 1:50 pm
and that you have the correct points :lol:
PostPosted: Fri Nov 11, 2005 10:30 pm
Put the car in neutral take the cap off and have someone tap the key just to turn car over but not start it points should open when resting on the corner of the shaft. Should be 12 thou clearence between. Where are you and ask someone near you to show you how to change your points. Important lesson easy to grasp anyone can do it.
Steve
 Post subject: Northside
PostPosted: Sat Nov 12, 2005 7:23 am
Wots your first name again Kenny and I'll give ya a call?? Just got the latest ACTMCC membership list ....we have struggled up to about 80 this year :roll:
I am working on cars all weekend Kenny....might be able to help...give us a hoy :wink:
Users browsing this forum: Bing [Bot] and 307 guests
