It is currently Sat Jul 19, 2025 1:45 am
 Post subject: Starter motor sticking
PostPosted: Mon Nov 14, 2005 10:05 am
My starter is spinning, but not engaging with the flywheel. I assume the bendix gear is sticking. What's the best way to clean and lube this?
PostPosted: Mon Nov 14, 2005 10:07 am
i think i got told metho to clean cant remember i just took mine to autoelecyy hows the bearinigs etc
PostPosted: Mon Nov 14, 2005 10:17 am
I had the same problem on the weekend, I just gave the shaft a hit with fine wet and dry and then a light smear of grease. Alright so far.
Steve.
PostPosted: Mon Nov 14, 2005 11:23 am
Haven't pulled it out yet so don't know what condition bearings etc are in - if it is stuffed I'll be putting a gemini one in anyway...
I was always told not to use grease? as it mixes with the clutch dust to make a grinding paste and wears things out faster? I was thinking some kind of graphite powder or other dry lube maybe?
PostPosted: Mon Nov 14, 2005 12:47 pm
I didn't put much grease on at all, just a light film, but I think you could be right. Oh well, if it breaks I will know not to do it again. What are the advantages of using a Gemini starter on the mini, I have one lying araound somewhere.
Steve.
PostPosted: Mon Nov 14, 2005 4:40 pm
I think mainly to get rid of the problem I have here - It is the pre engaged type. Also it has more torque, being of newer design and for a larger engine. People I have spoken too say it spins the motor over like there's no spark plugs in the head!!!
PostPosted: Mon Nov 14, 2005 7:53 pm
If it spins but does not engage the ring gear it could just need a lube or it could mean that the bendix gear has split and died :shock:
Pull the starter and check the bendix.
 Post subject: and the ring gear..
PostPosted: Mon Nov 14, 2005 8:03 pm
and the ring gear....sometimes they can get very gnarly and reject the advances of Miss Bendix... :roll:
Morrie :!: have you checked your answering machine :?: (tapping foot :lol: )
 Post subject: Re: and the ring gear..
PostPosted: Mon Nov 14, 2005 8:07 pm
Don't tap your foot, you will blow the pistons out of the wheel cylinders! Sorry Mick, no spare drums. :cry:
PostPosted: Mon Nov 14, 2005 8:43 pm
ewwhhhh.....tah....only if you are really heavy footed :roll: ......any ideas on where to get drums?? they are bigger than Minis aren't they :?: :?
PostPosted: Tue Nov 15, 2005 10:31 am
Clean it with Metho or Solvent and lube it with dry graphite , never put grease or oil on , it only attracts all the dirt and you end up with that same problem
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
Users browsing this forum: Bing [Bot] and 90 guests
