or
was given advice that if you want to get paint off without the blisters on your skin from stripper you should use brake fluid! this is more effective and cheaper than stripper as you use less quantities for the same surface area
use gloves? and pour it onto the panel, and then use a brush to move it. otherwise it flicks everywhere.
Wear safety glasses too.
After you have put the stuff on the panel, put newspaper over the top of it and damp it with a spray bottle.
when the paper dries on the surface then you can peel the stuff off.
use a CUP wire brush in your drill (so that it flicks to the sides and not towards you) to clean the residue off.
dont let the stuff dry onto the panel.
wash off with water, dry asap, wipe de-oxidine over panel, then use prepsol to clear bare metal, then prime (if 2pac) or get a spray can of etch primer and 'dust' the panel.
Deoxidine removes heat and rust scale, other acids and oils and more, refer to this link for more info.
http://www.chemicalcontacts.co.za/acid.htm
