It is currently Mon Aug 04, 2025 11:15 pm
 Post subject: tuning SU
PostPosted: Mon Nov 21, 2005 9:23 pm
Qick question,
If I want to lean my mixture on SU, looking from above with carby on car, I turn the big nut at the bottom of the jet anti-clockwise - yes?
PostPosted: Mon Nov 21, 2005 9:30 pm
lean is anti-clockwise
PostPosted: Mon Nov 21, 2005 9:43 pm
Thanks
PostPosted: Tue Nov 22, 2005 2:06 am
so when its leaner, its more economical???
and clockwise slightly should be a lil richer, and thus more performance??
1978 Leyland clubman S.
PostPosted: Tue Nov 22, 2005 7:34 am
my recent observations from playing with mixtures indicated that a too lean mixture will give you no power down low....to the point where you can hardly take off without riding the clutch a lot. A mixture that is too rich will feel powerfull, but possibly foul your plugs, cause excessive fuel comsumption and/or saturate your bores with petrol and cause premature wear.
Finding the right mixture is quite important!
PostPosted: Tue Nov 22, 2005 12:33 pm
Reason I ask is, I've put on my 1.75" SU which was tuned on 1275, on my 998. 50k's on the hwy the other day chewed half a tank, so I'll lean it out a bit I think....
PostPosted: Tue Nov 22, 2005 12:35 pm
:shock: 1.75" is too big for a 998
1.5" is as big as you want to go IMHO
PostPosted: Tue Nov 22, 2005 2:11 pm
AND the needle will definitley need changing!!!
PostPosted: Tue Nov 22, 2005 2:18 pm
ive got 1.5 SU and 998 engine.
free flow air. extractors.
what needle would do nicely for me??
i think the winSU told me to use a AAA.
but is that something i can just go to mini craft and get. or do ausies use different codes?
PostPosted: Tue Nov 22, 2005 6:31 pm
Yes I know 1.75 is too big, but I wanted to fit extractors to free the exhaust up a bit, and this carb was already bolted up nicely to an alloy manifold and has been rebuilt. No idea what needle it has, my mech tuned it with a file!!! Which is why I'm just going to experiment a bit with main mixture. Not worried about low speed torque (which is what theoretically suffers - not that I've noticed) as you have to rev its tits off to go anywhere anyway....
PostPosted: Tue Nov 22, 2005 8:39 pm
K-Bar, i would be looking at an ABD needle for the 998 like yours. Mine is similar - exhaust, LCB, alloy inlet manifold and K&N and i have made up an ABD needle for it (which i had to slightly tweek to richen it in certain points). ABD is a good starting point though
Mini - The Wizardry on Wheels!
