It is currently Fri Jul 18, 2025 9:04 pm
 Post subject: Mk1 Speedo
PostPosted: Wed Aug 04, 2004 8:40 pm
ANy one seen one of these
Its for Marcia. I'm Interseted if I can this speedo prior to Blue Slip :?: . Notice the numbers 8)
PostPosted: Wed Aug 04, 2004 8:46 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i think the morrie's had that colourd speedo
makka
PostPosted: Wed Aug 04, 2004 8:57 pm
Original Morris 850. Red needle.
I used to drive one... back then.. :wink:
Suits 3.765 diff and 10" wheels.
Last edited by drmini in aust on Wed Aug 04, 2004 8:57 pm, edited 1 time in total.
I dont care for Black and White so it not a real dramer.
It does say replacment on the box which is why i'm asking :idea:
Three thing to notice...1.3 on the odomiter, Dot above the 30 Mile mark and the fact it has a diferant arm..
Its a Mk 1 but otherwise I'm unsure. It's going into the rally dash and will love to get it past the 90mark. Additionaly will a Clubman Speedo cable Fit, I think So.
Otherwise I'm not to worried as it will be Dyno'd down at Franks otherwise Mini Classic/ Graham's
PostPosted: Wed Aug 04, 2004 9:15 pm
hey dude i think the hole above the 30 is so you know when you;re lights are on or something like that isnt it?
PostPosted: Wed Aug 04, 2004 9:25 pm
It is an early 850 speedo, it'll work yes but you will need to replace the speedo cable to the early type screw in one, rather than the clubman type. cost you about $20 odd dollars. This type of speedo people couldn't give away as they wanted the three clock binacle(black) ones. But are starting to make a come back it seems. As Dr said it is set for a specific ratio and you will probably need to get it setup for your car if you want it to read acurate. Mind you what mini speedo reads accurate?
PostPosted: Wed Aug 04, 2004 11:01 pm
MK1 speedo -same as the one in my 850. hole above the 30 is a blue hi beam indicator.
PostPosted: Wed Aug 04, 2004 11:07 pm
nah david if you look closely theres a high beam light in the centre at "12 oçlock"
its lust like a back light or something so you can actually read the dial at night or something
PostPosted: Wed Aug 04, 2004 11:37 pm
Sorry - I wasn't looking properly. My screen shown pics a bit dark so after loading it into a graphics probram and lightening I see what you are talking about and I have to say I don't have a clue. Dial is identical to mine but nothing at the 30 MPH mark.
Mine is out of the car and sitting by the computer as I type. The backlight comes in from under the black ring onto the face
PostPosted: Thu Aug 05, 2004 8:06 am
its not a hole but rather a dot. i guess backthen it was the speed limit
I hope I can get a cable long enought as I want the speedo behind the steeringwheel Bugger
PostPosted: Thu Aug 05, 2004 1:34 pm
I've seen a three binnacle Cooper/K instrument binnacle in front of the steering wheel, so it can be done. Or you could do like me and not bother with a speedo cable at all!
PostPosted: Thu Aug 05, 2004 2:35 pm
30MPH was the speed limit then but that dot is a touch beyond. Have you seen the actual unit or just the photo? Could it be an image artifact?
PostPosted: Thu Aug 05, 2004 7:18 pm
I did a speedo move on one years ago. Get a Morris 1100 speedo cable.. 8)
PostPosted: Thu Aug 05, 2004 8:11 pm
Speedo Cable
Aaron It is an early 850 speedo, it'll work yes but you will need to replace the speedo cable to the early type screw in one,
My Quote, I hope I can get a cable long enought as I want the speedo behind the steering wheel Bugger.
Anton I've seen a three binnacle Cooper/K instrument binnacle in front of the steering wheel, so it can be done. Or you could do like me and not bother with a speedo cable at all!
Possible I will not be able to get on long enought Enquiry time
Womdat 30MPH was the speed limit then but that dot is a touch beyond. Have you seen the actual unit or just the photo? Could it be an image artifact?
Yes I have the Speedo in my hot little hands and got a great price of Ebay with no one bidding. The spot is on the 30Mile mark
Im still interested on what you think regarding to having a 1.3Miles on the speedo for the blue slip. will they except it or expect the original odomiter with...yer what ever Miles on it. I will replace the old Speedo if need be for the slip and the switch them after
PostPosted: Thu Aug 05, 2004 8:40 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
just tell em the speedo craped it self
makka
