It is currently Tue Aug 12, 2025 11:05 am
PostPosted: Fri Dec 30, 2005 3:16 pm
Got some new CV's and wondering if the drive shafts I have formerly used with uni joints will accomodate a pot joint.
Thank you.
 Post subject: different
PostPosted: Fri Dec 30, 2005 3:21 pm
Andy .....pot joints need the correct output shfts...another problem for you.....Happy New Year :D
PostPosted: Fri Dec 30, 2005 3:23 pm
So they have a different type of spline on the end? Wish I had one of each to compare (trip to Tims???)
By the way, hanks for that link Mick but I think second hand is cheaper. Might post on here for a few actually.
 Post subject: just another photo....
PostPosted: Fri Dec 30, 2005 3:29 pm
Yeah...go see Tim and ask to see a pot-jointed gearbox.....there is a thread or two here explaining what you have to do....not easy...but worth it.
The link was to show you that any fool with a hacksaw and file could make those door spacers ....as I suggested :!: :shock:
(Caveat: any inference that Brom is any fool is unintentional and regretted :D )
PostPosted: Fri Dec 30, 2005 3:36 pm
Pot joint shafts are both longer, and have a different spline (and a circlip groove) at inner end than the others. :wink:
PostPosted: Fri Dec 30, 2005 3:54 pm
So I have disk brake CV's (for the disk brakes) and drive shafts.
I have discovered that the later style pot joint g/box is better and easier to find
Therefore I need to find pot joint style drive shafts for the cv joints instead of using the ones that came with the brakes?
[/quote]
PostPosted: Fri Dec 30, 2005 3:59 pm
yes. The shafts just pop out of CV after you smack them smartly with a BFH.. :wink:
Users browsing this forum: No registered users and 227 guests
