It is currently Sat Aug 23, 2025 6:35 pm
PostPosted: Thu Jan 05, 2006 3:26 pm
Just took the Traveller out of the garage for a quick drive this arvo, however when I pushed the brake pedal gently it went straight to the floor! when I then pressed it quickly it hadfull pressure. I've tried it several times and it will do it repeatedly.
There are no obvious leaks or loss of fluid so I can only think it's a master cylinder problem.
Any ideas guys before I rip it out?
1965 Morris Mini 'Woody' Traveller
PostPosted: Thu Jan 05, 2006 3:35 pm
probably not the master cylinder, cos it wouldn't hold any pressure, more likely some air has gotten into the system, or a brake line has turned into a balloon
PostPosted: Thu Jan 05, 2006 3:36 pm
Clamp off all brake lines and put your foot on the peddle, if it slowly sinks its the master if not start checking the wheel cylinders
steve
PostPosted: Thu Jan 05, 2006 3:42 pm
Cheers guys, I'll have a look in the morning.
PostPosted: Thu Jan 05, 2006 6:13 pm
Master cyls can do what he`s saying & when they do that , then it`s normally cause it`s internally by-passing, that is fluid will pass through the worn primary cup when pedal is gently pressed, but shove it hard & the cup expands greatly under the high pressure & seals (for now) :-)
easy-peasy
PostPosted: Thu Jan 05, 2006 6:16 pm
Has it been recently re-kitted???
I have seen this one - there are 2 sizes of master cylinder 0.70" and 0.75"
If a large bore master cylinder AND it is litted with the wrong [smaller] punger rubber, then on gentle pressure the fluid just leaks around the plunger rubber [still within the cylinder bore] and the pedal goes to the floor. But if you stab the peda hardl, the sudden pressure forces the cup out against the bore sides and pressure is maintained [while you have your foot on]
FWIW
Dat
Users browsing this forum: Bing [Bot] and 258 guests
