It is currently Thu Jul 31, 2025 7:07 am
 Post subject: Mini K Speedo
PostPosted: Tue Jan 10, 2006 8:03 pm
My Mini K has a 998 clubbie motor and box. Is the Speedo likely to read accurately.
The car should be on the road ina couple of weeks so I thought I had better ask the question
Nigel
Mini K, 1310, Jet Red/Crystal White Roof, Rover Interior
75 Clubman
PostPosted: Tue Jan 10, 2006 8:19 pm
Speedo is calibrated to diff ratio. I think Mini K had a different diff ratio to a clubby, so your speedo will read out.
Website: www.justanothermini.com
PostPosted: Tue Jan 10, 2006 8:26 pm
i found out if my was correct by driving passed one of those camerras which flash on a screen how fast your going. it was dead on :D !
PostPosted: Tue Jan 10, 2006 8:30 pm
Any one have any idea which way the speedo will read, fast or slow?
Really find driving to MPH a bit difficult anyway.
So clubbie speedo head in a casing to make it look like a tacho and a clubbie speedo cable, mount it so it is in front of the driver. Will need some globes in case it gets dark wired to existing dash lights. Wonder if a clubbie speedo cable is long enough to mount the unit on the steering column. All sounds OK?
75 Clubman
PostPosted: Tue Jan 10, 2006 8:34 pm
Your average rod change clubby 998 has a 3.44 diff. The Mini K has a 3.65 diff.
3.65 diff at 4000rpm in 4th gear with a 165/70 R10 tyre = 100.14km/h
3.44 diff at same revs, same gear, same tyre size = 106.25km/h
So your speedo will read 6% higher than actual road speed. But Mini speedos were never super accurate anyway. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Jan 10, 2006 8:36 pm
This will help...
http://www.skipspeedracing.com/misc/CalcSpeed/
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Jan 10, 2006 8:43 pm
Thanks Brett
Interesting site
So basically whatever the speedo indicates, I will be doing less, is that right?
Hope so as it gives a bit of leeway when passing cameras.
75 Clubman
PostPosted: Tue Jan 10, 2006 9:35 pm
Speedo will actually read slow, you will be going faster than it thinks by 6%, as you are putting taller diff in.. 8)
Might be almost accurate then! :lol:
PostPosted: Tue Jan 10, 2006 10:05 pm
Thanks Kev
A clubbie speedo is looking like a good idea. What do you think?
It would look like a tacho and to be honest I don't think I will be putting a tacho in this car
Nigel
75 Clubman
PostPosted: Tue Jan 10, 2006 10:12 pm
Klubman wrote:
Thanks Kev
Nigel
Clubby speedo would look crap in a roundnose, IMO. :lol:
If you want it same size as K one, to read pretty right and in KMH too, look for a big wheel Moke one. You want the one that has `800' marked on the centre part to right of where it says `Smiths'.
`800' means 800 turns/Km, which calculates out pretty close to the 1280 turns/mile of a Cooper S one. :wink:
PostPosted: Tue Jan 10, 2006 10:16 pm
Whats the availability of one of those going to be like?
So this would go in place of the existing speedo still located in the middle of the car.
Do you actually get used to looking over there for the speedo
75 Clubman
PostPosted: Tue Jan 10, 2006 10:26 pm
Yes it replaces existing one. We have a Moke one in Barney (wife's pretend S).
Yes, after 42 years of looking over there at one it's pretty good. Beats peering around the steering wheel at a Clubby one!
We're thinking about retrofitting a binnacle to the Clubby van... :wink:
PostPosted: Wed Jan 11, 2006 4:16 pm
wheel size got anything to do with throwing speedo out?
ook!
69 mini k
PostPosted: Wed Jan 11, 2006 4:56 pm
Car is not here to check tyres but the first issue is a mini K speedo with clubbie running bits
75 Clubman
PostPosted: Wed Jan 11, 2006 5:23 pm
<<Really find driving to MPH a bit difficult anyway. >>
Easy mental maths, Take the first number of the speed you should be doing eg. 60kph, will be 6, then multiply by 6 gives you 36MPH showing on your speedo, (well close enough anyway), so for 100kph will be 10 multiplied by 6 gives you 60MPH. Just need to know your 6 times tables.
Dino.
Over 1,000,000Km, but now my retirement restoration project
