It is currently Tue Aug 05, 2025 6:35 pm
 Post subject: Gauges Mini K
PostPosted: Sat Jan 21, 2006 5:43 pm
My temp and fuel don't work, is the voltage stabilser still available?
All my earths seem OK.
Nigel
Mini K, 1310, Jet Red/Crystal White Roof, Rover Interior
75 Clubman
PostPosted: Sat Jan 21, 2006 6:51 pm
PM `wombat' on this forum, he can sell you an electronic one cheap, so you can throw that 1950 technology away. I use them in both cars. :wink:
PostPosted: Sat Jan 21, 2006 7:08 pm
I bought a $7 voltage selector kit from Jaycar, ditched the selector resistors and, from memory, replaced them with a 3.3k ohm resistor to give a theoretical voltage or 10v.The measured voltage turned out to be a steady 9.9v.Place it into a small jiffy box and stick it behind the speedo. Seems to work well so far and its all mounted securely on a proper circuit board..
PostPosted: Sat Jan 21, 2006 7:30 pm
wombat uses a 10V voltage regulator chip, he just puts a couple of flying leads and spade lugs on it.
3 wires: 12VDC in, ground, 10VDC out. :wink:
no need to put it in a can with his latest version.
PostPosted: Sat Jan 21, 2006 7:31 pm
And Wombats one is a single transistor !
you can even put it inside the original "Can" if you want.....
Not saying yours isnt good Drekkus, but the Transistor one is superb...
Got one in the Brick... not a single problem in over 2 years so far !
J
PostPosted: Sat Jan 21, 2006 7:39 pm
Yeah, I tried going with the transistor method but for some reason I couldn't get it to work, It just kept overheating.The kit was my second choice but I'm happy with results.
PostPosted: Sun Jan 22, 2006 12:32 pm
.l
My fuel gauge jumped to full 3 days ago and stays there (obviously it does go back with the ign. off). Does this sound like a dead volt. reg.?
Temp gauge seems to work ok btw.
PostPosted: Sun Jan 22, 2006 2:43 pm
It could be. Those old 10V so-called voltage stabilizers do weird things when old. Usually whan they go dud, you get either 13+V or 0V. But mine used to give 10V at idle, then the faster you went the less it gave, due to vibration. So the fuel gauge used to drop with speed, then when I stopped it came back up. :?
I flung the stabilizer and fitted wombat's electronic one, and it's read fine ever since. :D
PostPosted: Tue Jan 24, 2006 6:55 am
Cheers Doc - I'll get it anyway and see if that helps.
PostPosted: Wed Jan 25, 2006 5:30 pm
$15 including postage PM me your address and I'll reply with payment details :wink:
David L
