It is currently Tue Aug 05, 2025 3:25 am
 Post subject: Fuel gauge
PostPosted: Wed Jan 25, 2006 10:54 pm
fuel gauge not working - any tips of where to start ?, using home made dip stick at the moment - not very 1977 !!
1977 Clubman
 Post subject: conections
PostPosted: Wed Jan 25, 2006 11:39 pm
Check all your connections first including the ones for the tank sender unit.
PostPosted: Thu Jan 26, 2006 12:11 am
where do the wires run from back to front of car - are they the ones underneathe the car ?
1977 Clubman
PostPosted: Thu Jan 26, 2006 12:58 am
i think they run along the roof not sure though :?
PostPosted: Thu Jan 26, 2006 1:14 am
id start behind the dash then trace your connections, prolly just loose somewhere
PostPosted: Thu Jan 26, 2006 7:29 am
Yep the wores run from the tankup the rear passenger side pillar with the rear lights wires along the roof, down the front window and into the dash
I would check that you have all clean connectionts and specialy the earth at the tank
