It is currently Sat Aug 16, 2025 1:52 pm
 Post subject: Driving tips
PostPosted: Fri Jan 27, 2006 7:19 pm
Hey guys and girls,
I'm driving to Sydney tomorrow from Terrigal. First stop will be Enmore for an hour, then it's off to Lillipilli around at 11am.
The thing I am worried about is that the engine has only done around 600 clicks. Has anybody got any tips on driving through the city and avoiding over-heating? I haven't got a thermo fan so that's out of the question. I'll be checking the coolant and oil level in the morning before I leave and will try to get to the city by 9:30am to beat the heat.
Scotty.
PostPosted: Fri Jan 27, 2006 7:26 pm
It shouldn't overheat should it?
When waiting in traffic don't sit too close to the car infront otherwise you're sucking in their hot exhaust fumes... :?
PostPosted: Fri Jan 27, 2006 7:27 pm
Harbour tunnel; and the Eastern Distributor
um..which exit I'm not sure but airport turn will get you to Mascot and its only up the road from thier :wink:
PostPosted: Fri Jan 27, 2006 7:48 pm
If the cooling system is in good nick it should have no problems Terrigal to Sydney..i've done it many times..
Only thing i have found is sitting dead stopped in a tunnel really starts to increase temps..so maybe avoid the tunnels if you're worried.
If you find it does heat up, pull over and let it cool for a bit..
Raising the revs a bit will also get the fan working a bit harder to circulate the air through the radiator, particularly if your idle is low.
PostPosted: Fri Jan 27, 2006 7:58 pm
you would not expect the Harbour tunnel to bank up on the Weekend?
PostPosted: Fri Jan 27, 2006 8:05 pm
If it does overheat, turning the heater on can sometimes help - extra volume and also that water in the loop is normally cooler til it circulates around and heats up.
But yeah, just pull over and let it rest for 15-20mins and try again. Once your're underway with fresh air flowing through again, it should be OK.
I agree with Gafmo, traffic shoudln't be too bad at 9:30 on a saturday.
KB
PostPosted: Fri Jan 27, 2006 9:31 pm
Yea, disregard my comment about tunnels...you should be fine on a sat..i'm just not with it..havn't done a working week in a while..in fact havn't driven in a month.. so i didn't take into consideration what traffic would be like tommorow..forgot it was saturday :lol:
PostPosted: Fri Jan 27, 2006 9:40 pm
PLus we never use the tunnel
You could use the Harbour bridge and go down George St (with Traffic light's) and onto Broadway and then turn left into Newtown!!
thier is always so many ways to get around Syndeys road blocks!!
PostPosted: Fri Jan 27, 2006 10:48 pm
Thanks guys. The plane is to head over the bridge, down George st, down into Enmore that way. I'll make sure I take a few vital tools ie: 1/2", 9/16" shifter, more coolant, gaf tape and WD40! :D
PostPosted: Sat Jan 28, 2006 12:33 am
sounds good, if its overheating, something is wrong with it :wink:
Users browsing this forum: No registered users and 346 guests
