It is currently Tue Aug 05, 2025 5:16 am
 Post subject: exhaust???
PostPosted: Fri Feb 24, 2006 6:32 pm
Hi I was just woundering if anyone could tell me if there is an exhaust flange gasket on a 72 clubman or the exhaust just bolts up to the manifold.Also does the reverse lights opperate the rear indicators or is there ment to be a seperate lamp. I have purchased my first mini in pieces and having a hard time putting it back together but having a lot of fun in the process. Cheers
PostPosted: Fri Feb 24, 2006 6:39 pm
yeh theres a manifold gasket/exaust flange gasket. same thing
http://cgi.ebay.com.au/MINI-Manifold-Gasket_W0QQitemZ4614170300QQcategoryZ32072QQrdZ1QQcmdZViewItem
buy that^^^
i think the reverse lamp is the indicator lamp.
we may need someone elses confirmation about this matter.
Image Image
PostPosted: Fri Feb 24, 2006 6:43 pm
Yes that pic is the gasket from manifold to head. But to answer the question, NO there is no gasket between the ex pipe and manifold, on a standard Clubman.. The flared pipe is just clamped to the manifold flange. :)
PostPosted: Fri Feb 24, 2006 6:44 pm
On mine (78 clubby) from memory it's the indicators as the reverse lights..both light up when you select reverse..
PostPosted: Fri Feb 24, 2006 6:45 pm
Early Clubby with remote box also had a reverse lamp switch, but I'm not sure it was connected to anything... :?
The later cars like Josh's had twin filament blinker bulbs- one for blink and one for R. :wink:
PostPosted: Fri Feb 24, 2006 7:38 pm
Hey doc, i actually have what i believe to be a reverse switch fitted just above the sump, when u look at it from the front of the car, its on the right hand side. Do metro gearboxs have these? because mines a remote as well.
Image Image
PostPosted: Fri Feb 24, 2006 9:26 pm
All remotes had them from around 71 on I think, they replace the hex plug in front of box, below oil filter.
Metros, like all rodchange boxes should have a switch on the shifter box, below gear lever...
