It is currently Fri Jul 18, 2025 7:00 pm
PostPosted: Sun Feb 26, 2006 8:03 am
so i put a charged battery in cracker this morning and turn the ignition on, i had dash lights but when i turned the key nothing at all happened :?
i have dash lights, head lights and horn but nothing else. there is absolutely no spark and the engine doesnt try to turn over at all
i guess i have pulled a wire off from somewhere but cant find it. Any Ideas?
I have replaced the whole front drum set up on both sides and replaced the bolt up oil filter with a spin on one. i cant think of anything that i have done to cause this apart from dissconnecting the wire that went to the old oil filter. this is not connected to anything now
any help would be great
PostPosted: Sun Feb 26, 2006 8:14 am
check all the leads going into the solenoid. If that's all kosher grab a multimeter and start diagnosing where you're losing power.
Shard
PostPosted: Sun Feb 26, 2006 8:16 am
i dont think it has a solenoid :!: or its not in the same place as they are on a clubby :?
i dont have a multi meter :cry:
PostPosted: Sun Feb 26, 2006 8:32 am
ALL FIXED A WIRE HAD SLIPPED OFF THE SOLENOID :D
does nayone know why there is that button in the engine bay that starts your engine? i accidently bumped it and she started :shock:
PostPosted: Sun Feb 26, 2006 8:34 am
Some solenoids have a button there , others have a bakelite lump that does nothing , not sure why but handy at times though I could imagine it could be lethal if someone put their hand on the wrong bit while the car was in gear .....
PostPosted: Sun Feb 26, 2006 9:15 am
To make it easier for servicing - also makes it easier for hotwiring!
Discontinued on later model cars :)
PostPosted: Sun Feb 26, 2006 11:24 am
Are there any cars easier to hotwire than a mini? considering many dont have an internal bonnet release and it take 2 secs with a jump starter pack?
off to NT I go
PostPosted: Sun Feb 26, 2006 12:21 pm
Mokes are slightly easier :).
Goodluck to anyone that ownes a moke and has an 850 steering rack that doesn't lock :shock:.
Shard
PostPosted: Sun Feb 26, 2006 5:23 pm
ive got an 850 steering rack that doesnt lock and no keys for the doors :lol: its real secure :shock:
PostPosted: Sun Feb 26, 2006 7:16 pm
I remember on a previous thread, somebody called that button the "run me over" button - hehehe :)
Bye
Rod Image
PostPosted: Sun Feb 26, 2006 10:43 pm
Bye
yep, left it in gear, and pressed the button outta curiosity.
Image Image
PostPosted: Mon Feb 27, 2006 7:59 am
Put a battery isolator switch in the boot... :lol:
Mightn't stop them, but will slow `em down.
PostPosted: Mon Feb 27, 2006 4:39 pm
i think some people have a hard time tryin to find the battery - which slows em down. I remember some had there mini trashed cause they couldnt find the battery or something, so they poured brake fluid all over it.
Image Image
PostPosted: Mon Feb 27, 2006 7:47 pm
An easy one that I have seen is take the dizzy cap off and remove the rotor and then put the dizzy cap back on. What's the chances they have a mini rotor in thier back pocket :D
A little bit harder with the pulsar dizzy but still doable and a potential thief could even have a mini rotor and it still wouldn't go :lol:
Roads need more corners
PostPosted: Mon Feb 27, 2006 8:06 pm
please explain this more? rotor? can u put it back in as easy ?
Image Image
