It is currently Mon Jul 28, 2025 1:45 pm
 Post subject: Brake light switch
PostPosted: Fri Mar 10, 2006 10:49 am
The brake light switch in my 95 mini cooper is playing up, It's fallen to pieces a couple of times and the contacts inside are now worn and keep bending apart after short amounts of driving. It looks like this:
http://cgi.ebay.com.au/Mechanical-Brake-light-switch-Mini-Triumph-Rover-NEW_W0QQitemZ4618761986QQcategoryZ32072QQrdZ1QQcmdZViewItem
Does anyone know if they are an easy to get off the shelf item, its obviously been used in a lot of different cars. ie. can I roll up to a Land rover or MG dealership and maybe buy one?
:) thanks
PostPosted: Fri Mar 10, 2006 10:55 am
Online
Im sure any switch with the correct power handling could be fitted to the pedal.
Just go into Dick Smith or Jaycar and find the closest size. Probably wont cost you
$24.95 either! :D
PostPosted: Fri Mar 10, 2006 1:22 pm
thanks for the idea, but i sourced one from a Land Rover parts counter.
part number is: 13H3735L and it cost $14.00.
I probably should of checked with them before I bothered posting. :roll:
