It is currently Mon Jul 28, 2025 7:06 pm
 Post subject: Brake light switch
PostPosted: Fri Mar 10, 2006 10:49 am
The brake light switch in my 95 mini cooper is playing up, It's fallen to pieces a couple of times and the contacts inside are now worn and keep bending apart after short amounts of driving. It looks like this:
http://cgi.ebay.com.au/Mechanical-Brake-light-switch-Mini-Triumph-Rover-NEW_W0QQitemZ4618761986QQcategoryZ32072QQrdZ1QQcmdZViewItem
Does anyone know if they are an easy to get off the shelf item, its obviously been used in a lot of different cars. ie. can I roll up to a Land rover or MG dealership and maybe buy one?
:) thanks
PostPosted: Fri Mar 10, 2006 10:55 am
Im sure any switch with the correct power handling could be fitted to the pedal.
Just go into Dick Smith or Jaycar and find the closest size. Probably wont cost you
$24.95 either! :D
PostPosted: Fri Mar 10, 2006 1:22 pm
thanks for the idea, but i sourced one from a Land Rover parts counter.
part number is: 13H3735L and it cost $14.00.
I probably should of checked with them before I bothered posting. :roll:
