It is currently Sat Jul 19, 2025 5:37 am
 Post subject: Oil filter question
PostPosted: Tue Aug 31, 2004 9:56 am
Can I pull the oil filter housing off without draining the oil?
The lump has the bolt on canister and I've picked up a spin on housing. When I first tried to replace it the engine was drained but I couldn't get the studs out of the block - then I didn't have the generator out - now its out I can see I have more room to get at the studs but there is now oil in the sump.
David L
PostPosted: Tue Aug 31, 2004 10:02 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
you will have a lil oil but not anything to worrie about just a dribble
makka
PostPosted: Tue Aug 31, 2004 7:17 pm
Yeah you'll lose a couple of tablespoons of oil (how many mL IS that?? :shock:) don't worry. Same amount as you lose when you change the filter now. 8)
