It is currently Sat Aug 09, 2025 9:08 pm
PostPosted: Mon Mar 13, 2006 5:50 pm
OK.. situation. I get in car, flick to reds, press the button, starts like a dream
Second situation. I get in car, flick to reds, press the button and the car feels like it has a flat battery. Starter motor WANTS to tick over, but doesnt
Ideas..? Suggestions. :?
PostPosted: Mon Mar 13, 2006 5:53 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
battery may be on it's last legs....
do you find this esspecially on colder mornings
makka
PostPosted: Mon Mar 13, 2006 5:55 pm
Nah brand new battery. I dont use any of the electricals so it must be getting charge Ok.
It happens hot, cold etc...
PostPosted: Mon Mar 13, 2006 6:35 pm
My experience is most often dodgy battery contacts get out and give them a wiggle and it starts OK. :wink:
Roads need more corners
PostPosted: Mon Mar 13, 2006 6:36 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
bad connection then
makka
PostPosted: Mon Mar 13, 2006 6:39 pm
Solenoid. 8)
PostPosted: Mon Mar 13, 2006 6:44 pm
Check the earth wire to body in boot, it's notorious for a bad connection.
Also check the one from clutch cover to RH inner guard.
Best to scrape paint to bare metal where the lug is, a bit of copper grease (antiseize) there and on bolt threads is nice too.
PostPosted: Mon Mar 13, 2006 7:05 pm
What is that one earthing? Where is the positive end of that one?
When he doesnt start, i clutch start him... is that bad..?? Am i doign the car damage?
PostPosted: Mon Mar 13, 2006 7:10 pm
I'd say check the earth aswell from starter soleniod to inner wing and battery and or plugs on the back off the key barrel
steve
PostPosted: Mon Mar 13, 2006 7:11 pm
it 'bridges' the earth from the body to the engine - your engine is all rubber mounted, about the only metal to metal connection is the accelerator and choke cable - wouldn't you hate to get a spark off one of those...
PostPosted: Mon Mar 13, 2006 7:18 pm
steve
hahahah.. you know i dont have fancy things like a key barrel
:D
OK looks like an earthing problem... that would explain why sometimes he is OK. Other tiems he is a stubborn little $hit... (its ok he is out of ear shot)
PostPosted: Mon Mar 13, 2006 7:44 pm
Marcello check how the starter was wired in your car or get it checked I remember it was a weird set up thats where I'd start
steve
PostPosted: Mon Mar 13, 2006 7:48 pm
Yeah all the wiring is S C R E W E D in that car... stupid electrical fire.
I just need to get him started one more time before he goes in for an Extreme Makeover..
:D
Hey i havent had a chance to talk to you, but i FINALLY got my Mini Convertible
http://www.ausmini.com/forums/viewtopic ... 369#232369
hehe
His name is Frank i have decided. Its as butch as i can think.... :wink:
 Post subject: No Start
PostPosted: Mon Mar 13, 2006 8:04 pm
Next time it happens, short out the starter solenoid (Use a jumper lead or heavy wire though). If the starter turns then solenoid is suspect.
PostPosted: Mon Mar 13, 2006 8:15 pm
Slow-Po
Good choice! :D
"Betty!"
:P :lol:
