It is currently Tue Aug 19, 2025 10:30 pm
PostPosted: Fri Mar 31, 2006 9:04 am
.... that i had a rear bumper on the front of my car?
Call yourselves friends....
:cry:
PostPosted: Fri Mar 31, 2006 9:08 am
Cause the car is butt ugly no matter where you look at it from! :D
PostPosted: Fri Mar 31, 2006 9:09 am
Cause it's a front bumper as well :? :lol: Just move the overriders and it will look right.
There is no difference between front and rear bumpers 8)
Roads need more corners
PostPosted: Fri Mar 31, 2006 9:10 am
I thought bumpers for front and rear only differed on clubbies.
No more Minis!......For now.
PostPosted: Fri Mar 31, 2006 9:12 am
Yup, The rear clubby bumper is very similar to the roundy front and rear bumpers and it will fit but the clubby one isn't as rounded (has a small step like bit in it) :wink:
PostPosted: Fri Mar 31, 2006 9:13 am
aren't there holes or something? how do the overriders attach?
PostPosted: Fri Mar 31, 2006 9:16 am
I think there is a nut welded on the inside of the bumper.
PostPosted: Fri Mar 31, 2006 9:18 am
I haven't looked real hard as my deluxe had no overiders but the overriders I got from finny had a plate that would fit on the inside of the bumper and I presume you tighten it up to clamp the overider in place. :wink:
PostPosted: Fri Mar 31, 2006 9:23 am
mine probably rattled loose and have been travelling to the out side of the bumper for 40 years :)
PostPosted: Fri Mar 31, 2006 2:38 pm
yeah mine that were on madmk1 were like that justa plate underneath, tighten the bolt/ loosen it and move it
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Mar 31, 2006 3:13 pm
nice.. i could rest my license plate up against one :)
PostPosted: Fri Mar 31, 2006 5:46 pm
theres no nut or anything on the inside, the overriders just have a clamp built into them which tightens up against the inside of the bumper and holds it in place -stick your head under the bumper and you'll see it - trouble is Cush, they'll have made yucky marks on the bumper where they've been sitting and it'll look bad if you move them
I always thought you had them there on purpose, it looks tougher than having them in the normal position closter together
leave them where they are.... unique like you ;)
PostPosted: Fri Mar 31, 2006 6:14 pm
Those overriders are worthless- later MiniMatics and Mini Ks didn't have them anyway!
Less wind resistance... 8)
PostPosted: Fri Mar 31, 2006 6:59 pm
Maybe PO put them there thinking it will protect the indicator lenses from carpark incidents etc.
PostPosted: Fri Mar 31, 2006 7:53 pm
becouse your arse is as Ugly as your face :idea:
I can't Talk..Mine been call an Apple :roll:
Users browsing this forum: No registered users and 530 guests
