It is currently Tue Aug 19, 2025 2:43 am
 Post subject: 45DCOE Weber Linkages...
PostPosted: Sun Apr 16, 2006 2:11 pm
Ok so the linkages on the weber weren't ever "right".
StuweyLS borrowed some part of the linkage and its never been right since :lol:
I was wondering if the posts, shaft, little wheel thing that goes on the end of the throttle shaft on the actual weber, connecting things, and anything associated, are still available for purchase?
I'd also like to see what arrangements others are using, as no two webers i have seen are the same :?
PostPosted: Sun Apr 16, 2006 2:41 pm
Here is what my moke had!
http://www.ausmini.com/forums/viewtopic ... ight=weber
PostPosted: Sun Apr 16, 2006 3:22 pm
I got a redline linkage kit for the redline 3005 inlet manifold.. I'm using it on a Dellorto. Let me say they are both a bag of crap.. the manifold is the worst casting I've seen, had to go at it with the die grinder before I put it anywhere near the mini..
and the linkage kit... :shock: :? nothing fits.. Had to cut and bend things to get it to work..DODGY.
PostPosted: Sun Apr 16, 2006 4:51 pm
My manifold is a Redline 3005, too, but with around 10 hours worth of porting inside.... :P
It now flows ~190-200CFM.
Lynx did a linkage kit too, but it wasn't much better.
Mine started as a Lynx kit but their POS plastic rose joints broke, it's now a bit of a hybrid, but it works better....
<edit> here's a better pic, when I had it on the Russell Engineering manifold- NO FILTER `coz no room.... :cry:
:wink:
PostPosted: Mon Apr 17, 2006 8:00 am
Kit prices now are about $100.... :cry:
The rose joints I used here are 5/16" UNF, available from any bearing supply house.
Add a bit of 5/16" rod and rob some carby arms off something, & you are in business.
Alternatively, hook a cable up to anchor on the rocker cover nut, and pull direct on the carb. These arm ratios are about 1:1 anyway. :wink:
PostPosted: Mon Apr 17, 2006 10:08 am
[here's a better pic, when I had it on the Russell Engineering manifold- NO FILTER `coz no room.... ]
Here's a suggestion - Try a HP Wwber filter housing from HP with a K&N filter - works a treat on a long manifold (from memory needs little if any modification to the speedo mounting hole - slight bend here and there)
[Alternatively, hook a cable up to anchor on the rocker cover nut, and pull direct on the carb. These arm ratios are about 1:1 anyway. ]
Good suggestion _ I used a very nice cable wheel (again a HP product) machined from alloy that is designed to overcome all the problems - worked beautifully on my J car.
Hope this is of some help!!!
Wild_willy
PostPosted: Mon Apr 17, 2006 1:25 pm
Yeah the ratios is what i am worried about.
I might be able to get away with the linkage i have there (i'll put pics up of mine later) but which hole do i put the little joint thing in :shock:
THeres like 5 holes... you'll see when i put the pics up.
I suppose this controls how much the butterfly opens in proportion to how far the pedal is pressed down.
AAAAAHhhhh too confusing.
Users browsing this forum: No registered users and 292 guests
