It is currently Wed Aug 06, 2025 2:31 am
 Post subject: compliace plates help
PostPosted: Sat Apr 29, 2006 10:09 pm
hi i have a mini van with no compliance plates is this a huge problem when i go to get RWC and rego for it wonce i have restored it???
PostPosted: Sat Apr 29, 2006 10:11 pm
What year is it?
PostPosted: Sat Apr 29, 2006 10:41 pm
I've got the exact same problem.. not even sure of the year.. I've got some investigating to do.. If it is after 71 (I think thats when the plates came in) will this be a major problem? What are my options, any dodgy way of getting round it?
Sorry, not trying to hyjack the thread.
PostPosted: Sat Apr 29, 2006 10:54 pm
VIN plates came in December 1969. :wink:
PostPosted: Sat Apr 29, 2006 10:58 pm
The car should have a chassis number. This will be stamped on the firewall or radiator shroud panel. You should be able to register the car with the chassis number if you can prove that the car has been previously registered. (You need to know the previous rego number)
Obviously it will be easier if it has the compliance plate.
If it was built before 1969 it will not have a compliance plate. (It will have an ID plate) It does not need an ID plate.
PostPosted: Sat Apr 29, 2006 11:17 pm
If built IN 1969 it will have neither plate probably, but as said the stamped body numbers should be there.
These days the inspectors (in NSW) seem to believe the radiator shroud number for rego purposes when you go for a blueslip, as that's what Clubbies have on the VIN plate too.
PostPosted: Sun Apr 30, 2006 6:13 am
i have the body number stamped on the radiator shroud it may be on the boday as well on the firewall but not sure cause its cotted in many layers of wo knows what. but the radiator shroud has been cut off but i still have it all i need to do is weld it back on but is there any way of telling what year it is from that???
PostPosted: Sun Apr 30, 2006 6:57 am
There is no formal register in Oz like the Heritage one in UK.
If you post the body prefix and most of the number here, people can make an educated guess.
Number sequence started at 501 for each body type- eg 850, Mini Deluxe, Mini K.
Original colour (if known) can help pinpoint the year too.
