im having massive problems with the travel in my clutch. i changed the clutch plate and pressure plate and thrust bearing i.e. clutch kit about 6 months ago because it ceompltely went on me. However when i pulled the old plates out, they werent worn that much at all, i found that the thrust bearing was almost egg shaped and really warped.
it has been fine up until now where im getting a huge shuddering between gears mainly first and second, as well as strong vibrations in the travel of the clutch that shakes my entire leg.
i have no idea what is going on. any help would be appreciated!
thanks
a girlfriend would be cheaper
