It is currently Fri Aug 08, 2025 7:56 am
 Post subject: Ignition barrel...
PostPosted: Wed May 24, 2006 12:37 am
Just wondering if on all your Mini's, do the ignition lights on the dash light up when the key is in the AUX position???
I wired in a stereo on the AUX wire so i wouldn't have to turn the radio off manually each time i get out of the car, but it seems that when the key is in AUX or ON (IGNITION) the dash lights do the same thing.
My dad thinks somethings wrong with the wiring somewhere.
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Wed May 24, 2006 6:41 am
Most Clubbies are like that, at least all the ones we've had. :wink:
PostPosted: Wed May 24, 2006 8:51 am
Just checked the LS and it does exactly as you described....
PostPosted: Wed May 24, 2006 8:52 am
i just wired mine so i have to turn it on and off each time bit of a pain but it still keeps i memory
PostPosted: Wed May 24, 2006 12:06 pm
NAV-MAN
Every clubbie i've plonked my but into has done it. not to worry as your ignition circuit isn't on
PostPosted: Wed May 24, 2006 12:22 pm
You sure? I thought that the coil had power going to it on 'aux'.
I always wire my minis to the constant side of the fuse box. No worries about frying coils that way.
PostPosted: Wed May 24, 2006 12:23 pm
its easy, on your fuse box (2-fuse type) get a test light or multimeter and find the fuse that has voltage only when your ign is on and then tap that for your stereo just make sure you have the wire on the correct side of the fuse as to not blow your stereo when lucas blows smoke! :twisted:
1975 Leyland Clubman 'S'
1976 Leyland Clubman 'S' *work in progress*
I smile everytime!
PostPosted: Wed May 24, 2006 12:24 pm
NAV-MAN
I never fried any points in aux listening to the stereo for a few hours at a time. but did in the on position :oops:
PostPosted: Wed May 24, 2006 8:40 pm
I'm with Stu.
I farked a condenser by doing this...
It definitely DOES power the coil in the AUX position (well did on my Green leyland, and the gold shitter too i think)
PostPosted: Thu May 25, 2006 12:01 am
So is there any way of keeping power to the stereo while in Aux, but not having the ignition lights???
Or should i just live with the fact that its old and get used to it?
Santo
"The Lone Ranger"
PostPosted: Thu May 25, 2006 12:48 am
NAV-MAN
Hmm maybe i've been lucky then. :shrugs:
