It is currently Sun Jul 27, 2025 8:31 pm
 Post subject: Camber Gauge
PostPosted: Thu May 25, 2006 10:13 am
Any 1 ever knocked up a simple camber gauge? Or know 1 on the market that is priced sensibly? Pulling the height down a little bit more as the Dunlop D01J's have created a bit more of a gap between the tyre n wheel arch due to lower profile. So gunna dial up a little less neg camber as already running 3 deg. Want to go with about 1.5 neg.
PostPosted: Thu May 25, 2006 9:21 pm
So im guessing no ideas here on this 1?
PostPosted: Thu May 25, 2006 9:25 pm
Take it to a wheel alignment shop for proper setting-up.
 Post subject: Geometry??
PostPosted: Thu May 25, 2006 9:26 pm
Flat surface, a way to determine the vertical (builders levels do it all the time) take some measurements....from the vertical....euclid was a smart man :roll:
PostPosted: Thu May 25, 2006 9:31 pm
I wont trust my car with some half wit wheel aligner!!!!
Its not hard to do. Ive got a few ideas for a camber gauge but thought some 1 may have knocked 1 up n have a few more ideas.
PostPosted: Thu May 25, 2006 9:33 pm
Drive to SA, there is an old bloke that owns Southern Wheel Alignment... been doing it for forty years.
We trust & use him regularly
PostPosted: Thu May 25, 2006 9:38 pm
Even still, i will not trust any 1 else to work on my car. Simple as that!!!!! I set the suspension up on this car to begin with. Was lucky enough that my housemate (mechanic) had access to there wheel alignment gear at his work. Took it in, i set it up n didnt change a thing was all spot on!!
PS: Id say im about 4000klms from SA
PostPosted: Fri May 26, 2006 6:17 am
Two easy methods: either builders level with a 360 pivot wheel thingy built in (mine cost $15 I think). Or a drop line and a ruler, hold drop line so it's hitting bottom of wheel, measure the distance from the drop line to the wheel (at the top), measure the height difference of the two points (along both sides of the triangle, and do a spot of geometry.
When I first got my level I did both methods to check the accuracy of the level but found it to be fine.
How are you doing caster?
PostPosted: Fri May 26, 2006 7:00 am
Brad, I have a camber/castor guage, but won't be able to help you for a couple of weeks, am away from Tuesday next week.
Steve
PostPosted: Fri May 26, 2006 7:33 am
Hey Steve,
Brilliant Thanks. I wasnt sure if you had one or not? Spose i should of just PM'd u! Thats fine, the way this weather is i still wont be driving the car for a bit. Ive put 8mm spacers on the front to bring the track out a tad. I still have good clearance between the tyre n the front of the gaurd.
Just looks like the car is sitting to high now because there is extra clearance between tyre n gaurd. Plus dosnt help that the sidewalls are sort of round where as the Yokos were quite square.
Thanks, let me know when u get back n we will work out a day.
PostPosted: Fri May 26, 2006 8:26 am
Please don't talk about the weather in Cairns...even the rain is warm up there...
Will someone please send me back :(
PostPosted: Fri May 26, 2006 12:49 pm
Well its practically been raining since Cyclone Larry at the start of the year. The sun has started to come out but is still to unpredictable.....
