It is currently Mon Aug 04, 2025 6:00 pm
 Post subject: The nuts and bolts
PostPosted: Sat May 27, 2006 11:55 pm
hi all,
A few months ago i purchased my clubbie :lol: , it is a rolling shell and i have been getting the credit card busy buying the bits to make it go. Just about to get some of the bits on and what do you know, no nuts bolts or any other fittings :oops: . So, can anyone tell me if there is any type of specification documents that will tell me the different types, sizes etc that i will need to buy??? Example, engine mount bolts etc.
:oops: :oops: :oops: :oops: :oops: :oops: :oops:
I'm guaranteed to break something every time, but there's nothing like getting under the bonnet and having a go!
PostPosted: Sun May 28, 2006 1:50 am
you can get bolt bags, particularly off EBAY to get you through.
http://cgi.ebay.com.au/BMC-MORRIS-AUSTI ... dZViewItem
Not everything, but it will help, at least you can go off to a bolt shop with the right size bolt and say "Give me a bag full of these".
PostPosted: Sun May 28, 2006 3:53 pm
Are the bolt spec's listed in the workshop manual??
PostPosted: Sun May 28, 2006 5:28 pm
I don't think you will have any problem with the tensile rating. Outside of the engine and perhaps some bolts in the suspension (Disc brake calliper and steering arm bolts spring to mind straight up) will you won't need any special hi-tensile bolts to bolt a mini back together. These aren't mild steel bolts, nor are they hi-tensile, and they will do fine. Avoid the plain mild steel bolts,they will simply shear in use.
I've never seen a list of bolts used in a Mini, you may just need to buy them as you go.
PostPosted: Sun May 28, 2006 7:55 pm
Mini spares centre in sydney has a, "pack of the most popular nuts, bolts and washers used to rebuild your mini".
I find there usually expensive but could be worth a try?
Mini spares centre
80 Gibson Avenue.
Padstow NSW 2211
Ph: 02- 97743366
Take it easy, & if it's easy take it twice!!
