It is currently Mon Aug 04, 2025 11:15 pm
 Post subject: shuddering clutch
PostPosted: Sun May 28, 2006 1:51 pm
im having massive problems with the travel in my clutch. i changed the clutch plate and pressure plate and thrust bearing i.e. clutch kit about 6 months ago because it ceompltely went on me. However when i pulled the old plates out, they werent worn that much at all, i found that the thrust bearing was almost egg shaped and really warped.
it has been fine up until now where im getting a huge shuddering between gears mainly first and second, as well as strong vibrations in the travel of the clutch that shakes my entire leg.
i have no idea what is going on. any help would be appreciated!
thanks
a girlfriend would be cheaper
PostPosted: Sun May 28, 2006 1:56 pm
Normally I've found clutch shudder to be caused by oil leaking onto the plate but it doesn't normally get as bad as you described , did you replace the big oil seal on the end of the crank when you did the clutch by any chance ? Is there any oil dripping out the hole with the split pin in the bottom of the clutch housing ? I doubt it would be that if it's so bad but it's simple to check and rule it out .
PostPosted: Sun May 28, 2006 2:00 pm
didnt change the seal, i do have a large oil leak but not sure if it enters the clutch housing at all and i will check.
it is completely dry around the split pin, i did notice that whilst he nut at the end ouf the clutch housing next to the lever arm doesnt turn, i can wiggle it a bit, would that have any bearing on it?
