It is currently Tue Jul 22, 2025 1:39 am
 Post subject: SU Dash Pot Oil
PostPosted: Sun Jun 04, 2006 12:10 pm
What type do people use and how much?
Im using some Singer oil and have put enough in my twins so that when the piston is fitted to the dashpot about 1/2 in from the thread i feel it contact the oil.
I had tried auto trans fluid some time ago but really remember if there was any difference in throttle response?
PostPosted: Sun Jun 04, 2006 1:12 pm
I also use singer sewing machine oil! I don't thing it would matter how much as long as it's more on the full side, than empty.
Take it easy, & if it's easy take it twice!!
PostPosted: Sun Jun 04, 2006 5:27 pm
i also use ATF on the recomendation of some wise people on this forum.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sun Jun 04, 2006 7:46 pm
In twin HS4s on Barney (1293) running #6 needles, I tried 20W/50 motor oil, then Singer 3 in 1 oil. Both were too thick and it would go way rich just off idle (checked with A/F meter).
I'm now using Dexron III ATF fluid, and it's sweet.:)
PostPosted: Sun Jun 04, 2006 8:30 pm
Hmmmm? Maybe i should revert back to ATF then? Waiting on some QW needles for the twin HS2 1/14's that are on my 1330cc. Tried an M but to lean, got AH2's now but is a little rich. So gunna try lean it out a little with some QW's????? Once i get them in ill drop some ATF in.
PostPosted: Sun Jun 04, 2006 8:32 pm
My HIF 6 went lean on full throttle acceleration with ATF so now it's got HPR30 back in it and it is way better. (Dodgy Dick Smith O2 meter but better than nothing).
PostPosted: Sun Jun 04, 2006 8:33 pm
Yeah think ill try oil and ATF once i get these needles sorted!
