It is currently Fri Jul 18, 2025 4:20 pm
 Post subject: Resleve bore?
PostPosted: Mon Jun 12, 2006 7:29 pm
I have a mk1 cooper s block that is out to 1380 but the bore is pretty crappy but can not go another rebore. The question I have is can I get the block resleved or is it easier and cheaper just to get another block?
Cheers Pete
PostPosted: Mon Jun 12, 2006 7:41 pm
Talk to Graham Russell. I know he can resleeve 1380s back to stock.
PostPosted: Mon Jun 12, 2006 7:50 pm
Thanks for that
Pete
PostPosted: Mon Jun 12, 2006 7:51 pm
However it won't be cheap. Unless it's a genuine S I'd grab a Morris 1100S, or a 1300 auto block... :wink:
PostPosted: Tue Jun 13, 2006 10:38 am
Spoke to Graham Russell today about this and he said it would be $150+ per bore, so looks like a new block.
Cheers Pete
PostPosted: Tue Jun 13, 2006 10:55 am
Cheers Pete
But hang on to your S block , another few years and it will be worth spending that much money on for someones resto , things are getting scarcer and scarcer .
PostPosted: Tue Jun 13, 2006 11:10 am
Yeh, was thinking about that.
Pete
PostPosted: Tue Jun 13, 2006 9:00 pm
1275 engines to suit a rebuild are going anywhere between $500 and $1500 already, so at $600 for 4 resleeves, it is not looking that bad IMHO
PostPosted: Tue Jun 13, 2006 9:11 pm
Picked up a virgin LS 1275 block today for under $300. Only thing wrong is the pistons were rusted in, but got them out OK. Will clean up no worries with 40+, hopeing 20+ will do it.
Pete
PostPosted: Tue Jun 13, 2006 10:41 pm
you could try to bore it out to 74.7mm like mine :-)
makes it a 1426 (ish) or even add a stroker crank & make it a 1485(ish)
Maybe,,,at least that`s another option if you want.
