It is currently Tue Jul 29, 2025 1:59 pm
 Post subject: head
PostPosted: Mon Aug 07, 2006 9:46 pm
hey guys i had a look at my head off my mini engine the other day and the head number was 2A629 i don't really know that many different head numbers but i have not seen this one before i think its just a standard head but if anyone knows anything about it that would be great.
Cheers Dan
PostPosted: Mon Aug 07, 2006 10:09 pm
My book says its a head off a 948 motor from either a Austin A35 or a Morris Minor
It has a 1.0625" inlet valve with a 24.5cc combustiob chamber.
by comparison, the 12G202 head has a 1.156" inlet valve with a 26.1cc combustion chamber.
The sports heads (12G295 and 12G206) have bigger valves again (1.218") and different sized combustion chambers (28.3cc) From the mini car clinic cattle dog.
Are they a good head ?? I dont know but with such small inlet valves I would doubt it. If the car goes okay then ?????
PostPosted: Mon Aug 07, 2006 10:23 pm
cheers mate
i never drove the car when the motor was in the car it idled ok and reved ok till it blew a head gasket but who knows how it drove??.,
Cheers Dan
PostPosted: Mon Aug 07, 2006 10:39 pm
2A629 was also used on original Morris 850.
Mike, your book is a misprint just like mine, the inlets on all these were 1.093". :wink:
They are the same inside as any of the round inlet ported smallbore heads- pretty tame in standard condition, but with enough work they can be made to flow.
But a 202 head takes less work. 8)
 Post subject: Cardwell
PostPosted: Mon Aug 07, 2006 10:57 pm
[quote="badassmini"]cheers mate
i never drove the car when the motor was in the car it idled ok and reved ok till it blew a head gasket but who knows how it drove??.,[/quote]
Twas a long time ago....but....I once drove a 998 Deluxe with a Morris Minor Head from Cardwell (Sth Cairns :D) to Sydney....worked just fine (thankfully :oops: :lol: )
PostPosted: Tue Aug 08, 2006 8:05 pm
would it be worth keeping a hold of being a 850 head
Cheers Dan
PostPosted: Tue Aug 08, 2006 8:08 pm
Would be desirable to someone doing an 850 resto as they were nearly always the first thing replaced in the search for power . Stick it in the corner and keep an eye on the wanted section , sooner or later someone will be looking for one .
