It is currently Tue Aug 19, 2025 6:00 pm
 Post subject: Ballast Resistors
PostPosted: Thu Aug 10, 2006 2:54 pm
I've gotta Triumph Stag/ jaguar E Type/ former Cooper S enthusiest here who on espying the Pulsar Dizzy upgrade in my mini is a little incredulous to see that a GT40R can be used without a ballast resistor for the whole time the engine is running.
I've had a search through the previous posts and hven't found anything that would answer his questions.
Did the Pulsars use ballast resistors at all, and what are the down sides for using a 1.5 ohm "R" coil that would make a ballast resistor a requirement in some installations?
Also what does the conversion do to the current draw of a standard ignition system? obviously as it is 1/2 the resistance, it must draw about twice the current, has anyone had to install a relay in the ignition system yet?
Mick
PostPosted: Thu Aug 10, 2006 5:05 pm
Pulsar N12 with Hitachi electronic dizzys used a Jap 1.5 ohm coil standard, with NO ballast resistor.
It just happens to be the same resistance as a GT40R.
Some other electronic ign systems use a 1.1 ohm or even less.
No big deal.
Ballast resistors are used in POINTS ignitions, not electronic. :wink:
<edit> the current draw is probably greater, but for how long is the question. They don't seem to get hot, as they do in a points system with no ballast resistor.
PostPosted: Thu Aug 10, 2006 6:16 pm
Thanks Doc, I suspected as much. I'll pass on your wisdom.
PostPosted: Thu Aug 10, 2006 7:38 pm
yeah the honda dizzys i built, i ran gt40r coils with them without a resistor.
edit heres some pics for inspiration
lookin for another clubby
Users browsing this forum: Sreedon and 81 guests
