It is currently Fri Aug 22, 2025 12:00 pm
PostPosted: Fri Aug 11, 2006 7:08 pm
http://cgi.ebay.co.uk/MINI-RACE-RALLY-B ... dZViewItem
Be a little lighter, seems 2 be a good way to go?, what would Aus Regs say about this?
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Fri Aug 11, 2006 7:13 pm
A lot of people in the UK have used them with very good results , a bit lighter , but a lot more adjustable and less likely to trap the salted slush from the roads ....
PostPosted: Fri Aug 11, 2006 7:32 pm
Thats pretty much the same as the Midas rear suspension except it uses the original trailing arms :D much like we used to run in the mini sportsedans :D
Jon
PostPosted: Fri Aug 11, 2006 7:46 pm
Doesn't vizard endorse these in his books? well a similar setup anyway
PostPosted: Fri Aug 11, 2006 8:43 pm
The name is misleading. It's note really a beam axle, just trailing arm with coil overs. Not bad, nice and light and same suspension geometry as standard mini.
