It is currently Thu Aug 07, 2025 6:58 am
PostPosted: Tue Sep 05, 2006 9:40 pm
ausmini mod
ausmini mod
Howdy,
So, the gearbox is on the table, the motor is ready, we flip it onto the box and start doing up the bolts.
What a pain in the a$$ we think.
How the heck did BMC put the bolts on?
NO WAY did someone sit there and do them all up with spanners... and wrench style ones dont fit (the gearbox housing hits)
Anyone???
Peter.
PS: Its on now, but there has to be a quicker, easier way
PostPosted: Tue Sep 05, 2006 9:49 pm
Probably just used a rattle gun. :D
PostPosted: Tue Sep 05, 2006 9:58 pm
probably with BMC special tool 18G23084578236 :wink:
PostPosted: Tue Sep 05, 2006 9:59 pm
The most common single tool to do it was prolly just the worker himself.
:D
PostPosted: Tue Sep 05, 2006 10:10 pm
It's easiest to do it with the block upside down, then fit box onto motor.
I have a few ring/OE spanners with the ring end ground thin. makes it easier... :wink:
PostPosted: Tue Sep 05, 2006 10:12 pm
ausmini mod
ausmini mod
Rattle gun wont fit there... no room and the engine and gearbox is too close to the nut.
Yeah, it was upside down but still a PITA!
Oh well, slow and steady I guess...
Peter.
PostPosted: Tue Sep 05, 2006 10:13 pm
ausmini mod
ausmini mod
Now, thats funny :D
Peter.
PostPosted: Wed Sep 06, 2006 7:54 am
I have a thin walled 7/16ths (1/4 drive) socket with a "wobble" type fittment thingy which i attach to an extension & then to my air tool.
sooper dooper cooper kwik, they`re all done within a minute, except for the 2 nuts above the diff, i do them with a spanner.
PostPosted: Wed Sep 06, 2006 9:00 am
ausmini mod
ausmini mod
Ah, now we are cooking!!!
OK, ill look into that :)
Peter
PostPosted: Wed Sep 06, 2006 7:39 pm
thier are a few sectrets that cant be mentioned...but its amazing how a spanner adjust's when its thrown against a walls many times
yer block upsidedown and then box ontop always :wink:
PostPosted: Wed Sep 06, 2006 9:51 pm
Hang on - I'll just put on my Anorak.... :lol:
Just had a quick hunt on www.britishpathe.com with a Mini factory search...
They have a great cradle gizmo - just flip over the engine and down comes the gearbox... but the nut fitting is still a secret..... unlike the head where they have a tool which does up all the nuts at once .....
(Images grabbed from 1257.01 "Wizardry on Wheels - Reel 2")
 Post subject: fingers
PostPosted: Wed Sep 06, 2006 9:55 pm
and watch your fingers when slipping the O Ring in before dropping the box :oops:
PostPosted: Wed Sep 06, 2006 9:57 pm
Or you could try " tube spanners "
Craig
PostPosted: Wed Sep 06, 2006 10:00 pm
Another related question....
The half moon seal has a raised lip onone side of it... which way round should this go ?
PostPosted: Wed Sep 06, 2006 10:15 pm
The big outer lip goes outwards against the timing cover backplate.
Make sure this plate is on the block when you fit the box, or the seal will extrude its way out... :wink:
